Results 16 to 30 of 50
Thread: Car losing traction in wet a lot
    Default Re: Car losing traction in wet a lot
    VL's have the same issue in the wet.
    My KE25 thread
    TAS
    For what it's worth my RA65 with modded 1G, good tyres (Falken 452 in very similar sizes to you - 225/45/16 & 205/50/16) and LSD is FAR better in the wet than it was with the 22RE, open-diff, worn 14s, and otherwise same suspension - and A6s are known for being quite light in the rear end.
    I would have thought Z2 would be better in this regard - so so it really sounds like tyre or maybe suspension issues.
    Convictania
    mate, dodgy bitumen - no doubt about it.
    Call your council and demand new bitumen or at least some snow chains.
    Quote Originally Posted by Stefan
    Or driver issues.
    Toymods Club Member
    Junior Member Domestic Engineer dfunkt's Avatar
    Apr 2007
    he mustn't be driving hard enough if he's only spinning on the uphills
    Owner of the Big Red Whale
    "i cant eat this because its too spicy" "i cant eat that because it has green stuff in it" "i cant eat that because its chilli soup with Blair's Ultra Death Sauce in it"... winge winge winge...
    Grid II's haven't been made in a while have they? While they have 80% tread, how grippy are they, are they old?
    same as others... check tyres first
    pressure?
    age? (if jcmo is right, they sound at least 5 years old - time for new ones)
    then when you replace your tyres you get an alignment as well, which will probably tell you you've bent a front control/steering arm or something
    Tyres I'd assume! Have they been in the sun lying around or something? My stockies were... and they are on the car at the moment, all it takes is a very careful foot, good thing about that, saves you fuel! GZ20's in mostly stock form in that chassis really feel like torqueless wonders, so I don't get how you're having an issue...
    i think the problem is that you dont have enough power with the 1g to heat the tyres up properly.
    try upgrading the engine to a jz for maximum fasts so that you can heat the tyres up properly so they will get traction in the wet.
    Nov 2007
    Raise the front...and install drag radials.....
    You can also place a brown coloured brick under the accelerator pedal...preventing it going all the way to the metal....
    Nov 2007
    I have not been driving the car like an idiot.
    Quote Originally Posted by Z2TT
    Hello,
    This has only happened once before, it was when I was doing skids and smashed into a kerb, when I smashed into the kerb the engine turned off.
    This Time I was doing skids in the wet again, but did not hit a kerb.
    The engine just turns off without hesitating or jerking.
    This is very unusual as I ussually drive my car hard, and has not happened all the other times.
    my mistake, that sounds like perfectly sensible driving. I retract my previous statement and applaud your upstanding driving as a shining example for the youth of today
    Convictania
    I do what he said ^ but naked.
    I'm home alone, hanging low and breezy.
    You can join me if you want
    Convictania
    Conceptually I'm down for anything.
  1. ABS TRACTION CNTRL and ESC lights staying on
    By TheStitt in forum Tech and Conversions
    Last Post: 12-03-2008, 07:08 PM
  2. Traction VS power
    Last Post: 04-07-2007, 12:56 AM
