Results 1 to 4 of 4
Thread: 4age- 4afe head
    Junior Member 1st year Apprentice duggy's Avatar
    Jul 2008
    Default 4age- 4afe head
    ok guys ive been all over the net tryin to find the answer to this question, so please if u can help let me no. well im tryin to find out if a 4age head will fit on a 4afe. and please if u know why they will or wont tell me why dnt just say yes or no. thanks in advance for all the help guys
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    Default Re: 4age- 4afe head
    You would be better off just getting a complete 4age. Given the blocks are the same there's little reason why the head shouldn't fit. However, the valve fly cuts on the pistons will most likely be different and you may run into compression issues. I would suggest that if you were to do it, you should strip the bottom end and use at the least 4age pistons. So, hence my first statement of get a complete 4age. The last one I bought cost me $50 from the wreckers in Vic.
    Alternatively, if you're going to so much effort you could use a 7afe bottom end and a 4age head.
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    Technically, it will fit. However, there are big differences in bottom end between 4AFE and 4AGE, which will most likely raise hassles along the way.
    Crank (GE is 8-bolt, FE is 6-bolt)
    Rods
    Pistons
    (whole bottom end of smallport and 20v GEs are forged)
    Alternator location (left/drivers side of block on GE, right/radiator side of block on FE)
    P/S pump location (reverse of above)
    Starter motor location (left/drivers side of block on FE, right/radiator side of block on GE)
    Water pipes (FE has radiator inlet and outlet both going into gearbox end of head, GE has inlet going to water pump, outlet coming from remote thermostat housing)
    Thermostat location (gearbox end of head on FE, remote housing on top of gearbox for GE)
    Ahh hell, basically the entire cooling system is different.
    In short, it is much easier to just drop in a complete 4AGE. There are plenty of them around, relatively cheap (a long motor isn't much more than a stand-alone head), no mucking around with internals etc etc. At the same time it'd also be worthwhile getting a C52 gearbox to replace the 4AFE's C50 (better ratios)
    Jul 2008
    http://www.rollaclub.com/board/?showtopic=22174 this should give u a better idea why i dnt wana change the whole motor and ive already got a head i just want to put it on so i can put my new manifold on
  1. 4AFC ---> 4AGE head
    By Grega in forum Tech and Conversions
    Last Post: 07-08-2007, 08:24 AM
  2. Are 4AGE head bolts supposed to use washers?
    By WHITCHY in forum Tech and Conversions
    Last Post: 27-06-2006, 07:13 PM
