You would be better off just getting a complete 4age. Given the blocks are the same there's little reason why the head shouldn't fit. However, the valve fly cuts on the pistons will most likely be different and you may run into compression issues. I would suggest that if you were to do it, you should strip the bottom end and use at the least 4age pistons. So, hence my first statement of get a complete 4age. The last one I bought cost me $50 from the wreckers in Vic.
Alternatively, if you're going to so much effort you could use a 7afe bottom end and a 4age head.
