Results 1 to 10 of 10
Thread: Bigger 4A/7A oil filter
    Default Bigger 4A/7A oil filter
    I popped into Toyota today to look for a bigger oil filter for the Suzuki engine in my racing car, (have been using a 4AGE/3SGTE one) and the guy behind the counter came out with a 1UZ one. It fits the Suzuki engine neatly, and out of curiosity I measured it up against the 7A block I have downstairs and I reckon it'll just fit. The o-ring will be right up against the outer edge of the mounting surface on the block, but I reckon it'll fit.
    I measured the 4AGE filter and the 1UZ one, and the 1UZ one is about 48% larger in volume. The part number is 90915-YZZD4.
    Thought some might find that of interest, if you're chasing a little less restriction and better filtering.
    www.billzilla.org
    Toymods founding member #3
    Default Re: Bigger 4A/7A oil filter
    i sue the D2/D4 filters on my hilux and was planning to start using them on my 4ag once i install the new oil cooler/filter felocation plate as it'll happily take a bigger filter although it must be a pretty tight fit onto the 4a mount.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    You can also ask for a YZZE2. It is the same diameter as the standard filter (YZZE1) but is longer. Used on Camry's etc.
    wrong.... the E2 is the correct filter for 4age/4agze engines.
    oregon
    Hmmmmmmmmmmmm, I'll have to check that out.... I wonder if the mocal adapter is wide enough?
    This might have to be merged with the cross compatibility thread..............
    ive tried it on my mocal fitting and it fits perfectly
    Here's a couple of photos for comparison.
    www.billzilla.org
    Junior Member
    Mar 2008
    Connecticut
    I've used the early Ford V8 filters on most of the Toyota engines I've had.
    Anti drain back "valve" & 1 quart capacity ...just check the thread pitch & O ring dia in the catalog to be sure.
    Hi Bill...been a long time
    'Allo stranger.
    www.billzilla.org
    I just found this which may be of use to people...
    Ryco's website has a very handy search that lets you specify dimensions & thread.
    http://www.rycofilters.com.au/catalogue/dimension
  1. TGP Oil filter differnces
    By TooF in forum Tech and Conversions
    Last Post: 11-03-2008, 08:42 AM
  2. Bigger Cat increasing backpressure?
    By kugzs in forum Tech and Conversions
    Last Post: 18-11-2006, 10:34 AM
  3. Oil Filter Interchangability
    By 3sgte in forum Tech and Conversions
    Last Post: 13-03-2006, 11:35 PM
