mate it could be either, but 1jz`s are dirt cheap if you got the motivation just purchase a complete short motor from a wrecker... and swap everything over...
well looks like i have one of them on my 1jz.
Getting some good cream under the oil cap now.![]()
I've tried researching the best way to go about fixing it, but since theres so little cases of this happening on a 1j i'm a bit lost.
1. If its a cracked head, wud the crack be repairable? Or should i be looking for a head.
2. Would it be cheaper replacing the motor? (i'll be doing work myself, except for any head work needed)
3. What are the chances my block is warped and wud require work?
Any suggestions wud mean alot!
1977 RA23 Celica -> 1ggte conversion [SOLD]
MA70 Supra 1JZ 5speed [SOLD]
Current: IS200 1JZ VVTI 6 speed
yeah
id be buying a long motor and swapping everything over
1. shouldnt be too hard finding a 2nd hand one to get reconditioned
2. depends how cheap you can get them over there
3. block should be fine
I know in NSW you can get a long motor without turbos for about $700ish...
Originally Posted by MR 1JZ
It depends how motivated you are...
You can get the headgasket for $168 (I got one not too long ago)
1JZ-GTE Head Gasket (Toyota: 11115-88410), $167.98, Southside Toyota
Or as said the other option is to find a long motor (no manifolds), and swap your stuff over! This is prbly the same amount of work as doing the head gasket, but less risk
You should be able to find a long motor for around $5-600...
The choice is yours![]()
mine popped a HG, i ended up buying a VRS kit, (headgasket included) had the head reco'd along with everything else on the motor.
hopefully it'll be alright ahhahah
mine same as above. i got ARP headstuds as well. had a problem with it sealing but sorted that out as well. it ended up costing me about 1100 including head recon and gaskets and stuff. that was at a workshop as well
Glenn
Current Ride http://www.toymods.net/forums/showthread.php?t=41123
Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
oh yeah, i got ARP headstuds, titan crank pulley etc.
it got expensive towards the end i guess.
I have a genuine toyota VRS if you end up pulling it down
Dave
