Results 46 to 60 of 66
Thread: How much Power from the 1jz???
  1. #46
    Default Re: How much Power from the 1jz???
    195.1rwkw...
    Yhe i imagine that the rear turbo may not last all that long, but i have plans for single very soon
    Oct 8, for the toyfest drags! Will have slicks and 18psi, which in theory should see me about 245-255rwkw...
    Jase
    JZA023
  2. #47
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    369rwkw with 2 shots of gas, and c16.
    265rwkw with no gas on pump fuel.
    NOT running steel wheel turbos. have seen 30psi out of them with no dramas, have never blown a set of turbos, a free flowing exhaust is the key.
    Unless you are running nitrous the headwork wont do that much for you.
    10.97 @127 with gas
    11.28 @120 without gas
    Thats a mx83 cressida with no backseat weighing 1365kg without driver.
    does run an auto though. Dieseltrains car would be alot more comparable to yours.
    i would say that with the manual it should make a good 250kw+ and if you want to push it you could probably get 270kw out of it.
    Also has alot to do with who tunes it. both I and Dieseltrains cars are tuned by Yavuz at Unigroup engineereing in girraween. and they are the 2 quickest stock turbo 1jz cars in the world.
    Boost, because of the 3.5" system and twin dumps should not be a problem to make because there is not much back pressure with that exhaust setup.
    been running our setup for 3 years, never blown a turbo, but have blown an engine because we ask our tuner to go ballistic. run 18-20psi on the street and it is daily driven by my brother.
    should have no trouble making 250+ at the wheels.
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
  3. #48
    Quote Originally Posted by jak
    280rwkw with no gas on pump fuel.
    dont you mean with c16? ...or is it a really optimistic dyno?
    JZA70|R / 12.45 @ 111 mph.
  4. #49
    Jun 2007
    yea sorry,
    280kw, no gas, c16
    265kw, no gas, pump fuel
    and our car has only ever been on that dyno.
    Jak
    10.74 @124 Mph
  5. #50
    Western Aus
    Yeah man, i know...
    Unfortunately the 1j lacks torque something serious...
    i reckon my setup should have enough of both for what i need... im not interested in drag racing the car though, coz i know with the suspension i put in it, ill have fuck all chance of a good launch...
    Stomps
    big call for someone that hasnt owned a car with a running 1J in it.
  6. #51
    if its a honest dyno, youve probably set a record with this figure as i dont know anyone thats managed to pump that kinda power from stock twins on pump fuel...
    ...would love to know your secret
  7. #52
    Jun 2008
    Daniel Clarke has made similar power from his stock twins jzz30
  8. #53
    I reckon the 1j has great torque! I popped a cooler pipe off yesterday and was putting around back home without it on, pulled well...
    WIthout boost though, it doesnt make any power
    Jase
    JZA023
  9. #54
    Quote Originally Posted by 131OWN
    I know, but not this much...
  10. #55
    Jun 2007
    hes only 5 kw off.
    Yavuz' dyno is used as a tuning tool not a "make people happy" dyno.
    Jak
    10.74 @124 Mph
  11. #56
    no i havent owned one with a running 1j in it...
    but i have driven... a jza70 auto and manual... my cousins jzz30 on numerous occasions...
    as far as i know, each of those cars had running 1j's in em....
    compared to the feel my 7m had.... compared to the feel of a 2j etc...
    i do like the feel of the 1j overall though...... from the ones i drove i loved em... especially the single turbo ones... not a fan of the twins unfortunately...
    Stomps
  12. #57
    Apr 2007
    Any 2.5 litre TURBO motor runing runing lower comp than a NA motor is going to feel less torquey down low, but with a 1J if you leave it all stockish & still with the factory twins i personally beleive from experience they are great & torquey down low ..
  13. #58
    Jun 2008
    Quote Originally Posted by JZA70 R
    your right, he made 257.9 rwkw
  14. #59
    on martini fuel... im only interested in 98ron figures.
  15. #60
    Forum Sponsor Conversion King
    Dec 2006
    you could get that on pump, just depends on how much work you do. cams with gears will help and i don't think Kade or Daniel have them in their engines.
    linden
  1. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 08:45 AM
  2. 3sGTE Intermitant 30-40% power loss
    By worldwalker in forum Tech and Conversions
    Last Post: 26-07-2007, 05:41 PM
  3. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  4. max safe power on 1JZ with std injectors and ecu (with FCD)??
    By RORZ_JZA70 in forum Tech and Conversions
    Last Post: 14-08-2006, 11:59 AM
