Yeah um I have?with dumps as well and some custom intakes but I have a walbro rather then a 044.
I suppose all Dynos will give different figures, the best way to find out what kinda your power really makes is to have a go down the 1/4! Cant lie about that
None the less, if i get more then 250rwkw on stock turbos, with 044, 2jz injectors and a PFC, front mount and exhaust, ** Some missing text**
Jase
EDITED FOR MY MENTAL HEALTH![]()
Yeh, i figure, i'll test my power on Rods dyno, and then i'll have a run at wsid with slicks... And if they both say 250rwkw, then maybe its possible
If it lasts with my abuse, then i'll plate my 1j twins in gold and keep them in my room as a statue!
Okay, hopeflly its obvious enough that all claims i have made, i actualy have no intention of following through with! Accept making lots of power, possibly even more than is sensible with my engine and car, and then doing skids!
Jase
No worries man...Originally Posted by Dieseltrain
I know i could get a lot more power if i went for the .82 rear.. (which i also had available at the time) and 272" cams (same price) but considering the car is gonna be used for drift, i need lots of midrange rather than just top end...
i cant wait..
Stomps
Got that right ! I couldnt care if my dyno said 200 or 250 or 300rwkw.... The 1/4 tells allOriginally Posted by Smokey228
And Stomps... SO many people forget about Torque.... They always so stuck up on HP !
11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series SoarerAnd 1st into the 11's
WOOOT!!!
Still going good![]()
Yeah man, i know...
Unfortunately the 1j lacks torque something serious...
i reckon my setup should have enough of both for what i need... im not interested in drag racing the car though, coz i know with the suspension i put in it, ill have fuck all chance of a good launch...
Stomps
All I am going to add is that nitrous fixes all issues of no torque 1j's![]()
hahahahahaha....Originally Posted by chris davey
yeah, but i cant go around using nitrous all around a circuit...![]()
still.... my brother has a spare nitrous kit sitting around... 1 of dyno run maybe...![]()
Stomps
My setup has made 255 rwkw (342 rwhp) @ 18 PSI
At 237 rwkw (319 rwhp) mark I ran 110 mph.
Didn't you go out and trap 104 mph after your 255 rwkw tune?Originally Posted by ReQuieM
JZA70|R / 12.45 @ 111 mph.
you won't need it with that setupOriginally Posted by Stomps
*boom-tish*Originally Posted by jza70 r
you cant compare 2 different dyno's, it doesnt work
when i had mine tuned, it put out 299rwhp
a couple of weeks later i put on a bigger aftermarket intercooler, which raised the boost from 14psi to 15psi, went to the OST dyno day at a different workshop and it put out 286rwhp.
I always use the same dyno whenever i changed anything on my setup to get real figures.. Although, i usually took it to the track as well and seen the results real world style too![]()
WOOOT!!!
That was with the 12.5psi tune (228rwkw) as the boost controller wasn't holding 18 good enought for a proper tune.Originally Posted by JZA70 R
But what would I know, I only own the car.
228rwkw should be gettin closer to 108mph... but some dynos are just happy![]()
WOOOT!!!
