1S-i or ci something like that was TBI, might be adaptable... saw a setup once in an early sv21 camry?
I was after Information on fitting EFI to a 2S-C, I have been looking and the easiest appears to be TBI, Not I was wondering if there is an Easy Fit Toyota Option, or something that can fit to a Weber 32/36 Adapter Plate.
I would Appreciate it if Someone has Ideas or even the Throttle Body itself, with Injectors. But Info on what / where to get would be helpful.
Thankyou, I will see if I can find one, Much Appreciated
Could you adapt the setup from a 2S-E?
Unfortunatly No as the 2S-E uses MPI, and will not fit under the Bonnet without Major Modifications
