Results 1 to 9 of 9
Thread: Stupid 2JZ Water Pump - Failed in an odd way.
    Default Stupid 2JZ Water Pump - Failed in an odd way.
    Well we fired up the 2JZ again last night to a nice flapping from the fanbelt. Stupid piece of crap water pump failed.
    Now has anyone ever seen one fail like this:
    Basically its walked its way forward on the spindle, the shaft and all.
    What im wondering is whether the impeller will still be attached to the shaft or if it will be floating somewhere else in the water galleries forcing me to pull down the lot
    Default Re: Stupid 2JZ Water Pump - Failed in an odd way.
    either way mate, its farked, the impella, if its come free should be sitting behind it, too big to go anywhere in the galleries.....
    Yeah, my guess would be that the impella is still in one piece, just sitting there watching the shaft spin nearby. Could have failed in a worse way... either catastropically or even silently.
    Those water pumps are a total cnut to get out. I did mine with the engine out (mid-conversion) and it was a PITA then. I can't imagine how much fun it'll be with the engine in the car. Good luck.
    Simon.
    1991 Toyota Cressida (JZX83).
    has the shaft walked forward too?
    what would cause it to move like that? is one of th eother pulleys on an angle?
    or the bearings in the water pump failed?
    what i mean is, unless something failed and caused an angle, there is no force trying to pull the pulley forwards.... so you need to fidn that too
    good luck!
    good luck!
    Good point. Normally the belt would tend to want to keep all the pulley wheels in a single plane. UNLESS... the waterpump pulley has failed in such a way that the shaft has angled downwards slightly and so the tension on the belt has resulted in a component of forward force.
    Simon.
    Nah, bearing has failed. I noticed that the pump pulley was on a bit of an angle, but i kind of ignored it, until we fired it up on Friday and it walked its way forward.
    Nope, no bearing failure. I suspect rather that the car had at one point sustained a front end impact and knocked the water pump pulley mounting plate thingy out of alignment.
    When i tapped the plate to knock the pump off the backing it did this:
    Can see its slightly ovalised too:
    Laterallly in this view.
    Banned 1st year Apprentice
    Apr 2008
    epic failz
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Nasty! Could have been worse though. On one of my cars, the pump failed by cracking around the neck, a piece of cast flew off it at speed, bent the fan and went straight through the radiator! Not a good sound to hear! Heres a pic of it..
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
  1. 3SGTE Water Pump Question
    By medwin46 in forum Tech and Conversions
    Last Post: 19-06-2010, 11:32 AM
  2. 4A water pump?
    By fandio in forum Tech and Conversions
    Last Post: 12-06-2008, 09:35 PM
  3. Water pump failure...
    By RobertoX in forum Tech and Conversions
    Last Post: 10-06-2008, 06:11 PM
  4. water injection pre turbo
    By project_x in forum Tech and Conversions
    Last Post: 28-03-2008, 08:41 AM
  5. AE101 front brakes and water pump + belts
    Last Post: 13-07-2006, 03:20 PM
