Results 1 to 6 of 6
Thread: 4A water pump?
    Jun 2006
    Default 4A water pump?
    i ordered this water pump for a 4agze prob about 3 years ago from new zealand, and when i only recently fitted it found the fitting on the back was for a hose rather then the usual flange for the ridgid pipe. the contour for the timing belt cover is different also.
    just wondering if anyone knew what engine it was for? thought it might have been a 20v pump? as i ordered 20v parts at the same time
    it bolts up fine, just fouls a bit on the timing belt (not good)
    its the one on the left, right one is a standard 100kw pump
    Default Re: 4A water pump?
    Yeh that straight contour for the timing belt cover, makes it look like a 20v pump to me.
    Whats the part number?
    same as the 20V silvertop ones I have seen too I beleive.....
    does the pulley fit the flange on the pump?
    If it doesn't, it's probably a 7A pump, if it does fit, probably a 20V pump.
    Jun 2006
    yeah the pulley fits
    unsure of the part number, threw the box out a while ago
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    its definately not a 4ac pump
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
  1. Water pump failure...
    By RobertoX in forum Tech and Conversions
    Last Post: 10-06-2008, 06:11 PM
  2. Electric Water Pump Options
    Last Post: 12-12-2007, 10:59 AM
  3. 18RG Water Pump
    By DingDing in forum Tech and Conversions
    Last Post: 16-10-2007, 09:06 PM
  4. 2JZGTE Water Pump Query
    By EvilJack in forum Tech and Conversions
    Last Post: 27-02-2006, 12:15 PM
