Results 16 to 21 of 21
Thread: Is an Idle Control Valve really needed?
    Default Re: Is an Idle Control Valve really needed?
    Im running a microtech on a 3s which has a 3wire stepper and cant actually use it because the doesnt support stepper control - it is a fairly massive pain in the arse i cant get the car to run right at cold atm and need to sit there warming her up till about 40 deg. IM aiming to try and adapt a 2 wire of some sort and mount that instead. If youc an use an ISCv, do as it sucks without one.
    STuC
    fwiw: XF falcon and ZL fairlane have a two wire PWM-controlled valve.
    some Hyundai have a replica of a large bosch 3 wire (12V, earth, PWM) and seem to have a substantial inlet/outlets and uses barbed fittings for hose.
    Quote Originally Posted by StuC
    STuC
    Replace the ISCV with a 20V one. Thats a 3 wire setup that is PWM controlled. And the Microtech can control it (assuming you have 2 ignition outputs free).
    btw, if you accidentally break a modern toyota ISCV (mine was from 7KE, but the JZ ones and later 4ag should be similar?) which has the PWM stuff to rotate a barrel to let air in...
    you can modify them so they are just driven by an old style choke cable setup (or a modern type with screw drive for more accuracy)
    not exactly flash, but no need for ECU control.. just means a bit of fiddling with the knob or lever when you first go to start car, adn the occasional tweak after it is warm
    of course ECU PWM is better...
    I like Stuff Backyard Mechanic mikie's Avatar
    would anyone be able to answer me this.
    is the Gen3 3SGE idle speed control valve an on/off type or something else.
    i pulled mine off to clean it out and have since then misplaced it. car now starts like poo.
    any help would be great.
    cheers mike
    hi guys
    sorry to wake a cold thread, but i'm looking to replace my setup with a plain TB and IACV.
    i'm looking for the IACV inlet/outlet to be hose fittings and the body of it not to bulky. PWM preffered.
    thechuckster said some Hyundai's
    anyone else offer some suggestions?
    i've seen this on ebay from a BMW 318i (pic below)
    that's what i'm looking for, but any others?
    RA65 - Project Car
    RT142- The 'I'm not sure what to do with it' car. (donor car)
    YZF1000R Thunderace
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. Idle Control with the 1jz
    By Mindless in forum Tech and Conversions
    Last Post: 22-01-2008, 01:17 PM
  3. What ECU do you use?
    Last Post: 06-12-2007, 10:42 AM
