ok i never went to turbo schoolsome fill me in on these specs
im looking at buying this t04 turbo to put on a 2jz
specs are
COMPRESSOR:
-Wheel- 64 Trim - 67.0 Inducer / 84.0 Major
-Housing- 100 Inlet / 60 Outlet - 0.70 A/R
TURBINE:
-Wheel- 76 Trim - 73.0 Major / 64.0 Exducer
-Housing- T04 inlet / 64.0 outlet - .96 A/R 70mm
all that is another language to me
The compressor is the cold bit of the turbo. the turbine is the hot bit of the turbo. all the numbers with . in front of them are ratios, and the numbers with . behind them are sizes(in mm)Originally Posted by The Count
GA23(never finished-now with cracked block) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
