Results 16 to 23 of 23
Thread: 16v 4age help
    Default Re: 16v 4age help
    righto, we are pretty sure the timing is fine (our reasoning is that the engine went hard before conversion)
    but here is an interesting fact... i had the RACQ guy come around to jump start the car (flat battery) and whilst he was here i got to test my motor with an array of shit he had.
    he had this light that you clip onto the injector plug on the loom... and when you crank it (still jump started to racq car) the light pulses, showing power to injectors.
    but here is the catch, the light was only coming up Dim. not fully bright. this shows that there isnt getting the required voltage to the injectors (ie: injectors are getting less then 12v)
    this would explain the rev problem im having, but does anyone know what would cause this?!
    Chiba
    Check, and then upgrade your engine to chassis ground.
    Mar 2008
    yeah i agree i'd check grounds in the first instance
    Traditionalist Domestic Engineer parrot's Avatar
    That would be page 4-15 of abovementioned manual.
    does anyone know where the injectors ground themselves from? (obviously) there are two wires going to an injector, im assuming one has 12v, and the other gets earthed....
    does anyone have an idea where i could find these wires?
    Junior Member Backyard Mechanic jono's Avatar
    Jun 2008
    i thought they were earthed through the ECU, as in constant 12v but switched ground.
    previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUXE
    current:-> 06 BF XR6T, MY13 ISUZU D-MAX 4X4
    thats what i thought too, so how would i check the earthing points?
    chrome is good Backyard Mechanic RO11LR's Avatar
    So did you end up fixing your problem dude ? i am having similar issues
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  2. 4AGE -> AE86 Conversion: Accessories question
    Last Post: 17-06-2008, 08:53 PM
  3. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
