Results 1 to 4 of 4
Thread: *4AG starter motor* works but not in car
    Aug 2006
    Default *4AG starter motor* works but not in car
    My car wont start, so I go to pick a part and get another Starter, get home put it in my car and the car still wont start, so I pull it apart and replace a bush that was worn but everything else looks fine, put it back in the car and it still doesn't work!!! so I pull it out and test it with some jumper leads, and it works fine, then I tested to see if the starter was getting power with my test light, and it is
    so now what the hell do i do?
    Its getting power, it deffinatly works, but as soon as i hook it up to my car it won't do anything.
    Please help, I'm sick of roll starting it.
    Modify is my middle name Grease Monkey Darola's Avatar
    Default Re: *4AG starter motor* works but not in car
    Hey there mate....
    check to see if u can turn the motor over by hand...
    Also check all earh wires.. common for the 4a to burn out the small earth wire from motor to body witch will stop starter... even with the big one connected...
    easy way to test.. add a wire from motor to body
    if the extra wire doesnt change then possible the starter cant work under load.. ie to turn motor over
    the extra wire should be the trick....
    Ed
    Eddie 0433 85 69 66
    Aug 2006
    Thanks mate, It turned out to be an earth issue, all good now.
    T'ville, QLD
    haha i was about to say bad earth, i had the same issue with teh 20v bad earth = ghey
    2T out 4A in....
  1. 4AGE reduction starter clarified
    By parrot in forum Tech and Conversions
    Last Post: 28-11-2011, 08:09 PM
  2. Starter Motor Wiring 4age Smallport - Ke30
    Last Post: 30-08-2006, 06:38 AM
  3. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 01:09 PM
  4. how to boost power to starter
    By warrior in forum FAQ
    Last Post: 01-03-2006, 04:49 PM
  5. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 08:34 PM
