Results 1 to 3 of 3
Thread: TA22 + Sigma Lower control arms
    Junior Member Backyard Mechanic sleeektoy's Avatar
    Jan 2007
    Auckland
    Default TA22 + Sigma Lower control arms
    Ok - bit of background...
    I have a 1972 TA22 Celica that i have decided to flare/spoiler/jacket
    I have been playing round with the front suspension setup to see what sort of results i can get in terms of looks/practicality with fitting the flares
    I have struck a bit of a problem that i'm hoping someone can answer.
    I have Fitted a GH sigma bottom arm, which fits with surprising ease.
    -same dia x-mbr bolt
    -same radius/caster arm bolt positioning/spacing
    -8mm different hole positioning for swaybar - (considered negligible)
    -50mm track width increase per side (brings tyres/wheels nicely out into flares) 8O
    I have RA28 struts with koni coil-overs which have all the usual adjustment
    I have adjustable top mounts
    THE PROBLEM!
    Since fitting the bottom arms i now have approx 4-4.5 deg negative camber
    Whilst this looks cool and fits perfectly with the flares i don't like the chances of survival of the inside of my tyres.
    left is factory TA22, right is GH sigma
    I have heard the *A60 supra struts induce positive camber into a TA22 if fitted, does anyone know the angle difference in the RA28 to *A60 kingpins?
    A possibility this could fix my issues?
    _____________________________________________
    TA27 GT - How rare can you get!!!
    RA28 GTV daily driver
    Default Re: TA22 + Sigma Lower control arms
    possible
    i also found rt132 corona struts have more kpi compared to ta22, another option to try
    there was a thread around with the differences between different struts in a kind of table format
    have a look for it in the search
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Jan 2007
    Auckland
    after a bit more searching - ive found it - thanks
    +3 deg camber by the sounds of it.
    maybe ill try it as-is and see
    BTW - heres a pic of the lower arm fitted
  1. Adjustable upper or lower trailing arms?
    Last Post: 01-05-2008, 08:03 PM
  2. good lower control arms for - camber to suit ta22?
    By dave-86 in forum Tech and Conversions
    Last Post: 07-04-2008, 08:52 AM
  3. Celica adjustable upper control arms
    By hypo23 in forum Tech and Conversions
    Last Post: 17-04-2006, 03:52 PM
  4. Help! Tell me what these control arms are out of?
    By 1973_KE20 in forum Tech and Conversions
    Last Post: 21-12-2005, 08:29 PM
