jeffro, keep that stone age garbage out of here![]()
They are easily die ground into submission.Originally Posted by oldcorollas
I will be using them on the blacktop throttles and have checked it out. As per Gabe from T3 also.
R.I.P Peter Brock.
so your saying build some straight runners approx 1" shorter than the t-vis plate to plenum or head to plenum? would retaining the t-vis with the bigport head help or hinder?Originally Posted by Ben Wilson
and i spose once i have it registered cutting some holes into the boot wont worry me.
indeed the t3 adaptor sure is prurty, but i do like making my own stuff at a fraction of the cost that IMO works as good. (even if i am not talented enough to make it from alloy!).
it appears all these adaptors space the itb's a certain distance from the head. i could always make some short and long ones and see what difference it makes on the local dyno.
thanks guy's, appriciate all the feed back.
they are mostly reasonably short because in a RWD application the TB's will hti the brake brake master/booster..
with the boot, you can make longer with no worries
Valve to plenum distance is what the air cares about.. I suppose you could keep the T-VIS if you were feeling tricky, it should still help.Originally Posted by feral4mr2
Now you're talking..Originally Posted by feral4mr2
Having built one myself, I'd seriously suggest buying one. It's not an easy job.Originally Posted by feral4mr2
Ill back that up, building them is a SERIOUS pain in the arse.Originally Posted by Ben Wilson
