Results 16 to 21 of 21
Thread: itb's and runners
    Toymods Club Member #274 Backyard Mechanic Rallystanza's Avatar
    Default Re: itb's and runners
    are the T3s for the 101 or 111 throttles? (they have different transitions...)
    They are easily die ground into submission.
    I will be using them on the blacktop throttles and have checked it out. As per Gabe from T3 also.
    R.I.P Peter Brock.
    jeffro, keep that stone age garbage out of here
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Quote Originally Posted by Ben Wilson
    It's a track car, don't stuff around having bends in the runners, just put the air filter in the boot. I can't find the numbers I ran, but with stock cams, a total runner length about 1" shorter than the factory runners should be a good start.
    so your saying build some straight runners approx 1" shorter than the t-vis plate to plenum or head to plenum? would retaining the t-vis with the bigport head help or hinder?
    and i spose once i have it registered cutting some holes into the boot wont worry me.
    indeed the t3 adaptor sure is prurty, but i do like making my own stuff at a fraction of the cost that IMO works as good. (even if i am not talented enough to make it from alloy!).
    it appears all these adaptors space the itb's a certain distance from the head. i could always make some short and long ones and see what difference it makes on the local dyno.
    thanks guy's, appriciate all the feed back.
    they are mostly reasonably short because in a RWD application the TB's will hti the brake brake master/booster..
    with the boot, you can make longer with no worries
    Quote Originally Posted by feral4mr2
    Valve to plenum distance is what the air cares about.. I suppose you could keep the T-VIS if you were feeling tricky, it should still help.
    Now you're talking..
    Having built one myself, I'd seriously suggest buying one. It's not an easy job.
    Ill back that up, building them is a SERIOUS pain in the arse.
  1. 1uz ITB's theory & advantages
    By Crambo in forum Engine & Driveline Conversions
    Last Post: 11-01-2008, 11:59 AM
  2. 7MGE and ITB's?
    By RObErT_RaTh in forum Tech and Conversions
    Last Post: 08-09-2007, 07:51 PM
  3. ITB's for 1jz
    By ReQuieM in forum Tech and Conversions
    Last Post: 21-03-2006, 03:43 PM
