Results 1 to 10 of 10
Thread: Small oil cooler roughly 20 x 10cm which cars have it?
    Nov 2007
    Default Small oil cooler roughly 20 x 10cm which cars have it?
    Hello,
    I am looking to find a car for wrecking that I can get a small oil cooler from, so I can use it as a power steering cooler on my car. Due to the limited amount of space I'm looking for something small, about 20 x 10cm. Which Cars have one that is about that size?
    Thanks.
    Z2TT
    senior backyard mechanic Grease Monkey legend's Avatar
    Default Re: Small oil cooler roughly 20 x 10cm which cars have it?
    twincam corolla is about that size
    Traditionalist Domestic Engineer parrot's Avatar
    AE82 4AGE corolla would be pretty close.
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    There are heaps of cars out there with small transmission coolers on them. A good one that I have used is one from a TP Magna.
    I have a Commodore auto trans cooler on my XX, probably about that size. I'm using it for my power steering
    What fittings do these have? Ive found that a lot of the OEM ones have 8mm fittings, and of course Toyota use 10mm fittings on the PS.
    Couple of screw fittings from memory (been while). I took the factory u-tube cooler in from memory, with the cooler and told them I wanted hosing and fittings to suit the thread of the cooler and the diameter of the factory tubing.
    It also had tabbed mounts on the sides so I was able to mount it on my aircon fan bracket just behind my intercooler piece of cake.
    i know a shop in o'connor that does these fittings.. pirtek i think it is.. they did some hydraulic fittings work for me, had a big range of parts i needed
    I went into Couplers in Malaga. Two thumbs up.
    AE92/93 also.
  1. JZS147 Aristo Cooler Setup
    By Mos in forum Tech and Conversions
    Last Post: 20-02-2007, 10:00 AM
