its a good question, lets go from the start then why I want this:
I like the idea of the oil warming up quicker on first startup and also having an oil cooler without any extenal oil lines/thermostat/cooler core. The 5S one fits like it was made for it, its just I have some serious doubts on how much it does considering it has crap all surface area for the oil to transfer the heat, the total oppersite can be said for the water though. So in my pig headedness I think I know of a better design. I just want it to equalise my oil and water temps without any real delays. With enough instruction and abuse of TAFE reasources I think I might be able to pull off making this.
That trd one looks nice, I would want straight outlets though. At this stage I am leaning towards milling one doing roughly the following steps:
getting two blocks of aluminium, machine them true and making them face each other
drilling, taping and counter-boring to make them bolt together possibly with locating dowels
drill and tap a water inlet and outlet unless I use another method to fix the steel pipes in there.
mill a cavity either side of the water pipes on the inside and from there using a dividing head and just one of the two plates cut a zig-zag slot all the way around. Repeated again for the oppersite side.
for one quarter of the section I would have it seperated for the oil, in this part I would machine a small accumulation cavity beween the two plates and then have a matrix of holes of a small diameter going to the top and bottom which the oil would work its way through. To make sure I dont strave my engine I would work out what the cross sectional area of the original oil return is and then work out how many holes I need to have the same amount as a minimum. Repeated the same for the top plate.
Finally with both sides bolted together I would put it on a rotating table and with a large end-mill I would make the outside mostly rounded shape except for around the fittings.
I really need to do a drawing.
(bottom of radiator)
