Bad photo, but this is all i can find that i think shows where the rx7 oil cooler lives
http://cp_www.tripod.com/rotary/images/pg17_10b.jpg
On top of the engine from memory, potentially on top of where the filter normally mounts, looking at that pic i've no idea how the oil feed side of things works, maybe threads onto the oil filter spot somehow, but that doesnt explain the bolts on the bottom nor does it look like that would cater for sealing the face of itOriginally Posted by Sam_Q
Yeah.. While heating the oil quicker is a bonus, its not my primary reason for doing this - maybe i'm dreaming hoping that there is a unit that will achieve a degree of both ?Originally Posted by YLD-16L
I assume that from the factory this runs between the block and the oil filter? Would you be running it this way or mounting it elsewhere?Originally Posted by Billzilla
Would running it against the block just mean the heat of the block will make it impossible for it to do much in the way of cooling?
Do you have any pics? Can't find anyOriginally Posted by trdee
Yeah they sit between the block & filter.Originally Posted by Bananaman
As long as you have plenty of water passing through it, it'll cool just fine I'd say.
www.billzilla.org
Toymods founding member #3
Where would i plumb it into the cooling system?Originally Posted by Billzilla
Next time i see the car i'll check my oil filter clearance to see if this is viable..
There's a couple of ways to do it -Originally Posted by Bananaman
- Tap into the exit of the water pump, where the pressure is the highest on the cool side, then plumb that through the cooler and then back into the hot side.
- Make a unit that fits into the cool water pipe into the water pump that has a small scoop, to pick up water.
- In either case, where you tap the hot water pipe back into the radiator .... I'm going to make up a bit of alloy pipe that has a small venturi in it and it'll help suck the water through that way.
www.billzilla.org
