It is known that the surface of the block can be a problem for old M engines purportedly due to a dissimilar metal issue with the gaskets. Pitting and rust does not make for a good seal. The block should be resurfaced if in doubt.
It would be great if there was a portable bolt on block surface grinder and a means of stopping the abrasives from getting into places it shouldn't - but there ain't.
So to do a good job, if in the case of corroded block surface, pull the engine and (check available tolerances) strip it down and send the block off to be skimmed, new welsh plugs, head bolt hole threads cleaned up, bores checked etc. New oil seals, gaskets etc.
Doing it once is cheaper than twice but getting half way and having only half a budget sucks.
Service intervals for an engine may not have been met - chains may be stretched, belts worn, guides worn etc.
You can try cutting corners but errors accumulate.
Are you going to use new head bolts?
You might get lucky!
D
