where do you buy nylon brushes? Do they mount in drill/die grinder?
FYI, Use a nylon brush attachment, not a wire one. The wire will scar the pullies. They nylon will eventually but so quick or as deep.
Bunnings have em. By jostik IIRC, they come in three grads of 'grit' something to the effect of 80, 120, 180. Cost about $12. You mount into your drill the same way as a wire brush. IE its a wheel with nylon fibres poking out instead of wire and has a metal pole through its axis which you just stick in your drills chuck.
I use it instead of a wire wheel for polishing as the wire wheel often does as much damages as it removes![]()
Brass brushes are quite soft also. Soft enough to not even scratch your hand.
