Results 1 to 15 of 19
Thread: Surface rust on pulleys
    Default Surface rust on pulleys
    My 2jz has been sitting around for ages and unfortunately some surface rust has materialized on the ribbed pulleys. Is this a concern for operation? Is there an easy method of removal without getting sandpaper into the ribs? Will this turn a belt into junk after a short time of running?
    James
    oregon
    Default Re: Surface rust on pulleys
    Hmmmmmmmmm.... there is a rust remover that is an acid base product.... "Naval Jelly" It sould remove any rust you have....
    i have used a belt before to clean it up but only do it if your willing to have it get eaten and possibly snap while your driving
    ive also used a wire brush attachment on a power drill that made short work of it
    id go for option 2
    EDIT dont bother using any rust treatment products is only surface rust, skim it off and put a belt on you'll be fine
    Ah good idea with the wire brush. I was thinking about sandblasting, but that would involve me removing every pulley and i cbf'd doing all that just for rust!
    if it is only light surface rust IE no flakes of rust (I presume the engine has been covered or stored indoors.... ) just start it up... should be clean in no time. ...
    Either wire brush it or just run a belt on it and monitor its wear/change it sooner than you normally would.
    metal wire brush that is softer than the pulley metal.. ie brass brush or whatever..
    hard wire brush might put lots scratches perhaps? see how ya go
    Maybe a picture would help in getting a better idea on what will/wont work.
    Victoria, Mt Macedon
    I vote firmly for fitting the belt, running the engine and promptly forgetting about the problem.
    Hen
    yeah, I'm with hen.
    Unless there is serious pitting or flaking, it will come up clean after a good run. Had the same thing on my 1G.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    If you're that worried, run the original belt that came with the engine, and after the pulleys "clean themselves" fit the new belt.
    Mos.
    ffs this is not a major crisis
    hen x3
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Ok cool i'll run the old belt to clean them up LOL cheers guys for your input, muchly appreciated.
    before and after pics?
    It's gonna be a while before I start this engine, so I wouldn't hold your breath
  1. Wanted Advice About Rust On Gearbox Cogs
    Last Post: 02-10-2006, 12:16 PM
  2. Ghetto Rust Repairs
    By derekjay in forum Tech and Conversions
    Last Post: 08-05-2006, 09:43 PM
  3. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 01:14 PM
