Results 1 to 15 of 23
Thread: JZA70/Z20 Rear Camber ?
    West Australia
    Default JZA70/Z20 Rear Camber ?
    Hey all,
    Since smashing the soarer into the tyre wall at collie and repairing the damage, i have found that to align the wheels again is difficult due to this section being loose/worn ?:
    Im unsure of what its called but i need that RING thing that rotates around when adjusting Toe/Camber arms on both rear sides replaced as it seems to just slip past the mounts that help it push arms in and out due to wearing down (i guess ?) . Wether it be Aftermarket or stock replacement i need both rear toe and rear camber ring things....
    Can someone please tell me what its called so i can ask for it in the wanted section or search yahoo auctions.
    Cheers.
    Forum Sponsor Backyard Mechanic Soarer21's Avatar
    Default Re: JZA70/Z20 Rear Camber ?
    They're just a concentric washer for camber adjustment. Toe is adjusted by the tie-rod ends. There's probably millions of those washers floating around in peoples garages.
    I'll have some on this pos soarer Im pulling apart if you're desperate enough to pay postage costs from Qld to WA. Im sure there'll be someone close to you with them though, surely?
    I'd rather have a bottle in front of me then a frontal lobotomy
    HP Guru Backyard Mechanic driftedmz20's Avatar
    Jan 2008
    yeah they shouldnt bee too hard to get at all
    West Australia
    Thanks John + Drifted
    Have you ever heard of these wearing out ? or could my Wheel Alignment place be talkin crap.
    Coz when they were attempting to align the wheels, the guy would rotate the bolt/washer, and it would get to a certain point (lets say negative 2.2 deg camber) then when trying to reduce camber more it would "Slip" out or something and the arm would pop back out...
    Jan 2008
    to be honest i cant say ive ever heard of that. wearing out like that. i can certainly ask someone for you if you wish which has 20+yrs in suspension and knows his shit
    ive never done an alignment on a z20 but done plenty of other cars and have never seen it..
    ill see what i can find out for you coFF
    West Australia
    Keep in mind Drifted, my car has had like 6 wheel alignments since ive had it (2.5 or so years) and probably like 10 more before then.
    Coz its either that or the camber arms are bent ?..
    Hopefully someone in perth is wrecking a supra/z20 ... but probably unlikely
    Jan 2008
    trying to find out for you and will let you know
    West Australia
    Well i found a wrecked Z20 in Perth, so im gonna go up there and ask HOWMUCH
    prolly be like $200 or something spastic like that , lol
    Junior Member Automotive Encyclopaedia big JON's Avatar
    May 2006
    Whats the brace going across underneath the gearbox? I cant work it out in the pic
    JZA70 Twin Turbo R - 301.3rwkW @ 18psi
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    ^^ +1
    im like wtf is that
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Jan 2008
    coFF
    you want to do the honours or shall i??
    there is only 1 place ive seen those and you can get them for the rear too!
    West Australia
    go ahead my friend
    Grumpy old prick Automotive Encyclopaedia Looonie's Avatar
    Aug 2006
    Auckland
    The entire setup is available new from Toyota, the bolt, rings, washers and nut are all available individually.
    However they are highly unlikely to have warn out. Bear in mind that the way they are designed, is that you rotate the bolt to push the lower arm in/out (bolt acts like a camshaft and moves the arm as you turn it) but it will get to a certain point at the peak of the curve on the concentric washers where it will not push out any further and will in fact start pulling back in again.
    If your car is lowered or banged up, its highly likely that you will go past this point before getting the adjustment you need, hence why adjustable arms are useful.
    But also bear in mind that the two "tabs" that these concentric washers act on are merely bent metal on the subframe, and are known to get flattened out if some twonk has a go at doing your wheel alignment. Best thing to do is get under there yourself, remove the concentric washers, get a hammer and whack the tabs back up so they are perpendicular to the subframe surface again, and drop a small bead of weld in behind them to stop them bending flat again. This should improve the range you can achieve through a wheel alignment on the factory gear.
    Moo
    Apparently I was advertising in my signature, where I just thought I was helping out others... so if you want to know how to get more steering lock in your A70/Z20 Supra/Soarer, you'll just have to search, don't ask me, apparently I'm not allowed to tell you.
    Aug 2006
    Auckland
    Quote Originally Posted by big JON
    Aftermarket lower subframe brace...
    To replace the puny factory item:
    Note: They are normally straight Thats just the only photo I've got of one.
    Moo
    May 2006
    ahh cool, cheers. Looks like you clobbered something well
    By The Witzl in forum FAQ
  2. How to: Supra MA70 rear discs to Hilux
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 13-01-2019, 11:12 AM
  3. FYI Rear Live axle configuration RT104GT
    Last Post: 31-08-2006, 06:41 AM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
