The first thing is does it actually feel like a clutch when you press the clutch pedal in?
I'm going to assume it does or you would have mentioned it so this could mean either...
1. The pressure plate is frucked, (it happens sometimes, it just feels completly normal but no longer lifts as high as it should and so doesn't function)
2. some sorta problem with the spitgot bearing.
3. you bent the clutch plate sliding the box in on an angle, OR the wrecker bent the plate when taking off the old box (again not too likely but possible)
4. Throwout bearing is different (doubt it)
OR (and I hope it's this)
5. The old plate is stuck to the flywheel with rust or whatever from just sitting around at the wreckers, and when you disengage the clutch the disc is still spinning stuck on the flywheel. Best way to check for this (and fix it at the same time) is to stick the car in first with the engine off, push the clutch in and turn the key. If it's rusted stuck this will free it up and your in buisness, but otherwise start the car in gear, go for a drive, press the clutch in and use the brake to slow the car. If you can get the clutch to slip or at least some feel you might be in a better position to judge where it's at. Hope this helps!
Linkages are fine as the gears shift while engine not running, and we've tried adjusting the slave rod as far as we can in both directions, without change to symptoms - clutch just doesn't seem to let go
