Results 61 to 75 of 79
Thread: 5MGE Rebuild Begins... Cams anyone ?
  1. #61
    Default Re: 5MGE Rebuild Begins... Cams anyone ?
    Once you make one part looks clean and tidy and painted it looks out of place unless everything is like that. I like the 'original' look it has
  2. #62
    Jun 2008
    Hah yer, I was wondering when ppl would point that out...
    I actually have another set of covers which I am in the process of cleaning up.
    (just getting sick of cleaning shit).
    I was going to have a chat with a few ppl about cam work and then change em to some
    textured red & milled silver finish
    "For the performance 5MGE model upgrade JDM Red Top Special drift edition etc....grin"
    Just hangin out to drive it again~!
  3. #63
    Junior Member Grease Monkey Kroozerdave's Avatar
    Apr 2008
    looking forward to that picture just to finish it off.
    Assume by then it'll probably be reinstalled ?
  4. #64
    Jun 2008
    Smile The Mighty 5M Lives again!!!
    Been busy this weekend,
    Installed engine on Saturday, hooked up about %75 of the hoses / wires.
    Installed tail-shaft, filled gearbox…. drip drip F*#n new rear gearbox seal leaks…
    Pull t/s out, inspect seal. yep looks ok, check the measurements, damn supplied seal is 1.5mm to large on the seal side
    Looked at spare (new) camshaft seal, hmmm, extracted gearbox seal, measured up looks like it should do the job…
    Sunday, installed new camshaft / gearbox rear seal, re-filled box no drips Whoo!
    Installed remaining hoses / electrics, installed my custom thermo fan controller box thingy, cleaned up a few other wiring bits n pieces.
    Filled up engine oil (5.7L worth for dry fill). no drips.. cool.
    Filled up cooling system Bloody water pump is weeping ever so slightly, GOD DAMN IT!!! was a fairly new pump too…. will fix later....
    About ½ hour ago, triple checked all hoses / electrics, cranked engine round by hand a couple more times. Ran a no-ignition test to get oil pressure up, appears ok.
    Ignition on, crank BRooooomm!!!, fired up 1st time, didn’t even have to stuff around with the ignition timing.
    Sounds like a bloody diesel though. I think the lifters are not ‘lifting’ so good, hoping they will come good when I do a full warm up run tomorrow, will also get hold of
    an oil pressure gauge to make sure its up to spec, and it is ideling waay to high (about 2200rpm), with the screws all the way in, will double check for leaks later...
    So far so good(ish), bit miffed about the water pump, as it never showed signs of trouble before, Will post up some U tube 1st startup footage later…
  5. #65
    Jun 2008
    Default Re: 5MGE Rebuild. She runs !!
    Another quick update,
    Checked over the ignition timing / vac lines, oil pressure (~60psi)
    Fired it up yesterday, let it work up for about 5 min, the rattle went away ! yay !
    Adjusted the thermo fan controller kit to switch once it was fully warmed up,
    went for a quick test drive up the road, still not %100, tends to surge a little
    I think this may be part due to my TPS been near on rooted.
    Any one have a old 5M tps (switch type) handy?
    Have attempted to glue it back together, but dont think it will last. The plastic has gone really brittle.
    Just a few little bits n pieces to re attach and will be finished, finally!
    -A
  6. #66
    Looking good but please paint the cam covers.
    Jordan
  7. #67
    Jun 2008
    Default Re: 5MGE Rebuild Begins... 1st run video up !
    Bump,
    You tube clip is up.
    http://www.youtube.com/watch?v=9Ipa_fl4ALo
    -A
  8. #68
    Nice, but you know what excited me the most? You have a blue dashmat for your MA61 just as I do
  9. #69
    Jun 2008
    Smile 5MGE Rebuild Is Complete !
    Quote Originally Posted by RObErT_RaTh
    Haha,
    I think every toyota I have owned has come with a manditory blue dash mat ;p
    Took it for a good thrash-in on sunday, runs a treat & a little more rev happy now.
    Kept up with some random guy's ma70 turbo, grin.
    -A
  10. #70
    south austraila
    if you are intrested i have an USDM MA67 manual ECU...
    Project: '82, GA61 XX
  11. #71
    Jun 2008
    Hi GA61, whats the difference on the ECU for a MA67??
    May be interested.
    I do have the whole engine wire harness for the 'newer' (digital?) model 5mge (with stepper motor icv & manifold)
    Do they all run the same ignition system?
  12. #72
    Jun 2008
    Default 5MGE Rebuild Finishing touches, Sexy cam covers
    OK one final pic for the project...
    The cam covers fellas.
    Happy now
    -A
  13. #73
    vic
    Ah shit it looks like a nissan motor now LOL
    Dave
  14. #74
    Quote Originally Posted by cambelt1
    Dave
    Actually the first thought that came to my mind was ferrari, looks tight
  15. #75
    Jun 2008
    Cheerz doods.
    This thing is running like a charm now.
    Did the 3rd oil change this w'end, now on semi syn.
    Is great to drive, more revvy since changed to good oil!
    -A
  1. Toymods and CAMS Affiliation
    By twentyEight in forum Toymods Car Club Membership and Feedback
    Last Post: 19-11-2007, 03:11 PM
  2. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  3. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
