if I was getting an engine tuned I would be more worried that the bad tuner would do more than just a bad a/r, but instead causing broken internals through detonation.
Continuing from what AF300e said; another thing to keep in mind is that the combustion chamber design has a big effect on the maximum dynamic comp that can be run. Modern pent roof quick burn chambers with good squish areas work wonders compared to some of the older detonation inducing engines. Thats why the old holden 5 litre engines sopposedly ran an 8:1 comp (8.3:1 advertised)
Piston size again changes everything, in direct comparasin if two identical engines are compared and one has half the diplacement then it can have a higher CR.
So it is not possible to have an overall chart of maximum static compression ratios because all head models burn different and also have different cams. All this even before tuning even comes into the picture.
I dont know if it would help anyone but I wrote an article on working out the static CR of engines, its based around the 4A engine but the concepts are all the same. I have checked it many times and no-one has gotten back to me saying its wrong but I could be as I had to work it out for myself. So if you see something you dont like then let me know ok?
http://www.ae86drivingclub.com.au/fa...ression-ratios
