Results 1 to 5 of 5
Thread: MX83 Steering Problem
    Oct 2007
    Default MX83 Steering Problem
    So there is a problem with the steering in my Cressida. When I turn left or right it makes a grinding noise and there is a bit of play. I have been searching the forum a fair bit and a leaking steering rack seems to be a common thing but my power steering fluid is still on max and hasn’t gone down at all so it really has me puzzled to what it could be. There is also a squeaky noise in the suspension that I guess would be the rubber bushes, could that have anything to do with it.
    Default Re: MX83 Steering Problem
    Steering rack, steering rack bushes or even the PS pump.
    Perhaps a worn wheel bearing. Jack the car up and spin the wheel and see if it makes grinding noises and/or has play. Play can also come from worn suspension components.
    Nov 2007
    The squeaky noise is it when you go over speed bumps? if so it will be your front caster bushes.
    Does the grinding noise start at full lock or just with normal driving?
    Oct 2007
    I just had a go with the grease gun and put some graphite grease in all of the bushes and it has stopped all of the noises. There is still a bit of play in the steering but I cant remember if it was always like that. I will soon be replacing them all with polyurethane bushes anyway.
  1. RA23/28 with KE70 steering column and rack and pinion
    Last Post: 24-01-2017, 03:39 PM
  2. Holy Sh*t TA22 Steering Improvement!!!
    By 75Ta22LT in forum Tech and Conversions
    Last Post: 30-10-2008, 12:30 AM
  3. Steering help, freeplay on drivers side wheel
    By Da_Ronz in forum Tech and Conversions
    Last Post: 09-01-2007, 09:39 PM
  4. Possible power steering problem?
    By tooch in forum Tech and Conversions
    Last Post: 04-01-2007, 11:26 PM
  5. 162 Celica Steering Rack Help!!!!!!!!!!
    Last Post: 03-05-2006, 05:43 PM
