Results 46 to 60 of 66
Thread: Bee*R rev limiter Installation Guide (JZA70 specific)
  1. #46
    Junior Member Grease Monkey Pr0j3kt_SuPrA's Avatar
    Default Re: Bee*R rev limiter Installation Guide (JZA70 specific)
    Quote Originally Posted by JZA70 R
    i have two, both 2nd hand. one for $150 and the other was free cause it was fried. but we got it fixed for $55 so thats pretty sweet, but now the original owner wants it back
    original owner is an indian giver!!! esp if it was broken to begin with
  2. #47
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    come and get the other one if you want dude...do a switcheroo and see if its the unit
    let me know if you want it...might be able to drop off later
    Alright cool.
    If you come up this way drop it off for me and i want to see that 6 of yours . If your not dont worry bout it untill later.
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
  3. #48
    ok man...ill call you when i leave mine
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  4. #49
    Ok got the another Bee*R lastnight and put it in this morning and works fine :S
    Now need to go some where to get it fixed.
    Anyone?
  5. #50
    i just got mine fixed for $55 from precision electronics in W.A.
    last dude to wire it up thought the green and yellow wire were +12v and earth :S
    the guy that fixed it said it was a impressive little bit of kit. he loves japanese electronics and admired the programmable chip on there.
    he even tested it was working on his test bench which i thought was cool.
    JZA70|R / 12.45 @ 111 mph.
  6. #51
    -Street Drag Machine- Grease Monkey renxun's Avatar
    Jan 2007
    Sabah
    anyone wiling to do favour and send me a set for me to try? *smile* im willing to buy over if its reasonable. as long as its working condition and not faulty units...
    Drift Drift Drift and drift untill getting high fever...
  7. #52
    ive actually got a problem with mine now that its installed... hoping someone else has installed one on a 1j and can help me.
    we hooked it up according to the instructions, the unit almost does everything right. it powers up and detects the correct rpm but when the cut is initiated the computer picks up on the event and the motor goes into limp mode for a brief second. so yes it cuts the ignition at the correct rpm but instead of it repeatedly cutting, it cuts once then the motor stalls almost completely and then it will rev and repeat that process.
    we know we have power, earth, c.a.s and the clutch cable hooked up right, but im guessing theres something wrong with the ignition signal we used.
  8. #53
    got mine fitted up but doesnt seem to run properly...and how would u "shield" ur connections? the unit doesnt seem to cut properly and i cant rev past 5-6 grand even when i set the cut alot higher... possibly bad connections? as i have SAFC + SLD wiried up so they are sharing a few connections
  9. #54
    welcome to the club.
    did you follow this guide to wire it up? ...everyone i know has and they are all having the same problem so maybe its the guide?
    this diagram is off the japanese bee*r website, i think its the same as this guide thought.
  10. #55
    mmm yeh followed the guide.... yeh possibly i wonder if its maybe it needs a more accurate/clean ignition signal from sumwhere else instead of the crank sensor? my unit just doesnt seem to run like it should...
  11. #56
    May 2008
    doesnt the 1JZGTE like the 1G ECU have 2 PINS for RPM?? when i wired up my mates SAFC in JZA70 Supra we connected like the APEXI diagram and wired it to RPM1 which gave out an RPM, but for example stock gauge shows IDLE of 700rpm and SAFC was showing 3200rpm....we then switched to RPM 2 and it was ok......maybe trying switching the wires to differant RPM wire???
    RPM 1 AND RPM 2
    1992 - JZA70 STOCK - SOLD
  12. #57
    May 2008
    according to that japenese BeeR diagram you currently would have it at RPM SIGNAL 1 I would try RPM SIGNAL 2
    check my dogey diagram copied for SAFC 2 install
  13. #58
    hmmmzzz might try that....thing is my Bee*R shares the same ign signal wire with the SAFC and the safc shows correct RPM :S
  14. #59
    Junior Member Backyard Mechanic gwilmarlio's Avatar
    dude you are not alone I have one on my JZA70 with the stock ecu
    I does work on the launch control part but it was cutting the revs at 6500rpm no mater how high I set the rev limit
    to get around this so far I have installed a soft switch in my center console so I can use the launch control and have the stock rev cut works great now my other prob is I have a power FC and it doesnt work with that FFS
    somthing to do with the FC has some grounding issue that I cant find any more info about
    this site is the closest I have come to a solution http://www.skyline-owners-club.com/f...-power-fc.html
    looking at the ECU pin outs X24 is the ground but there is X26 and X13 that are earth,manafold
    I am thinking of trying the power FC on X26 or X13 any thoughts
    1990 JZA70 R 12.959sec at 112.78 mph Kwinana Motorplex
    1J torsen smashing machine
    TR44 Highflow single (366whp at 17psi)
    1988 GA70 SOLD and will be missed
  15. #60
    hmmzzz i think connecting the FC to a different ground might upset how it reads the sensors( i think they use the same "ground") has anyone tried wiring the Bee*R black wire straight to chassis? coz i think what happens (just a theory) when the Bee*R cuts ign it sends the ignition signal(+12V i assume) thru ground thus effectively ground isnt ground anymore as it has a positive charge.
    what do u think of my thesis?
  1. Why is my 2jz-gte hitting rev limiter?
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 11-10-2006, 01:39 PM
  2. Using Jaycar Rev limiter as "valet mode"
    Last Post: 17-04-2006, 10:33 AM
