Results 1 to 13 of 13
Thread: 18rg help asap
    Default 18rg help asap
    hey, i just got my whole engine reconditioned because of a spun bearing but we dont have the adjustable chain guide that the tensioner pushes on, is there anywhere that i can source one from?? does anyone have one for sale. also can someone please let me know where the gears have to aligned to setup the timing. thank you
    Washington, USA
    Default Re: 18rg help asap
    while not the identical unit.. the one from a 4M, 5ME will work.
    Grind about 6mm off the end and round it before installing.
    It works great, and doesn't have the oil leak problem of the orignal.
    If you have trouble locating one, shoot me a PM and I can get you one.
    For the timing you'll need a RG/TG timing tool to be spot on. but as a general eyeball
    timing have the #1 intake lobe at 9-O'clock and #1 exhaust lobe at 3-O'clock.
    Is yours the 3 bolt style cams or the single bolt and pin style?
    72 RA21, 77 RA29, 78 RA40, 79 RA42, 83 RA65c, 85 RN60
    81 RA42 race car, 04 F150 supercab tow rig.
    thanks for the info but i meant the bottom chain gear setup, top end is easy.does the m series one go up too far in the head??
    Washington, USA
    BGB shows both crank and pump drive shaft at 12 o'clock on both keyways.
    cranks gear timing mark at 6-o'clock.
    pump shaft timing mark at just before 12 o'clock (timing mark looks to be about 1.5 teeth
    to the left of 12,( @ 11 o'clock is to far)).
    2nd gear on pump shaft shows at 6 o'clock timing mark.
    torque is 6-7kg-m.
    damn scanner is nackered atmo. or i would just post a scan.
    thank you . . . . would my 3tgte guide fit??
    Washington, USA
    Quote Originally Posted by lilcrash
    i doubt it, but it can't hurt to try it ?
    lilcrash - you can buy the setup brand new... the bottom chain setup is IDENTICAL to an 18R-C, so just buy an 18RC timing chain kit and it will have what you need.
    The last one I bought cost me $15 on ebay
    here ya go - this guy has one... you want the LATE 18R timing chain kit, someone asks about it in the questions below this listing.
    http://cgi.ebay.com.au/BRAND-NEW-TIM...2em118Q2el1247
    thanks for the info, just to be sure, that kit will include the top chain tensioner guide yer? also is the top chain the same as the 3tgte or different as i have a spare sitting here and if i can use it. it will save me money
    that kit is for an 18RC... so the top chain is totally different. But it will have all the bottom chain stuff you need for an 18RG.
    The chain guide between the camshafts IS the same as the 3T-GTE one, and is still available from Toyota.
    sorry to sound rude but that didnt answer my question. the only parts i dont have brand new are the tensioner guide. (bent one with the thing on the back for the tensioner to push on) and the chains
    south australia
    the bent one in an 18rc is a bit different to the rg one (the one the tensioner pushes onto)
    i can't rememebr if the 18rc one had more or less of a curve to it though. i think river posted the pictures to the 18r assembly which might have pictures of the 2 in it (try the FAQ section first before searching, you might get lucky)
    steveM said he used an 18rc one (aftermarket pressed one as i think the oem one is a cast piece) and bent it (slowly) to match the shape of the 18rg (again this is memeory from reading threads about this over the various years and my memory aint what it was like a couple of years ago)
    and yes 4m and 5m tensioners work, i had one in mine at one stage
    well your first two posts are contradictory.... firstly you say you needed the slipper chain guide that is tensioned by the no.2 chain tensioner (for upper chain, intake side).... then in your next post you say you are talking about the lower chain...
    ... hence the confusion.
    Apparently you can take the 18RC slipper chain tensioner guide and "bend" it into shape to suit the 18RG setup. I think SteveM did this.
    sorry for confusing you. just out of curiosity, has any one had any problems with just getting the original re coated??
  1. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 09:09 AM
  2. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
