Results 16 to 23 of 23
Thread: Is this Bump Steer??
    Default Re: Is this Bump Steer??
    Quote Originally Posted by Hurricane
    ive got a similar problem in my ke20 , i think ive ttraced it to one of my steering arm bushes being worn,
    cheers,dan
    but steering arms have no bushes in them
    Quote Originally Posted by RobertoX
    Making a bump steer guage is a good idea, I'm not sure how puhn suggests it but I've done this before by attaching a flat surface to a wheel and then used 2 dial guages to measure the toe change as I moved the suspension through it's range of travel.
    pretty much the same
    May 2008
    Tennessee
    Deleted as question already answered
    Junior Member Domestic Engineer Hurricane's Avatar
    Quote Originally Posted by SeptemberSquall
    as a ke20 doesnt have a steering rack, i cant think of the name, but on the oposite side to the steering box there is a arm that comes off the chassis to the steering arm, and its got a bush in it.
    but yes it will not be the same for the 86 as its running steering rack.
    but if this ball joints were worn it would be doin a similar thing in a way.
    cheers,dan
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    New Zealand
    have to be scarily worn joints!!
    sounds like the issue is lack of RCAs to me.
    only way to correct is with RCAs or raising ride height
    you need to correct the alignment of the rack vs steering arms
    hope this helps hurricane
    Yellow Belly Black Snake Backyard Mechanic Sprinter-Saurus's Avatar
    New South Wales
    I'd almost guarantee it's bump steer induced by the S13 gear, I have the same effect in my KE70 with S13 coilovers. Is there no way at all possible to run RCA's Tom86, a few guys on DC have used them and it solves most of the problem. What sort of brakes are you running?
    1984 MA61 Supra - 7mge.
    Toyota Hilux 2.8L TD 4x4.
    Quote Originally Posted by Sprinter-Saurus
    Yeah I've tried fitting a 35mm RCA on the car and the lower control arm actually touch the disc rotor. I'm thinking of getting a smaller RCA like a 10 or 20mm one to see if that will be any better. Anyone have a 10mm or 20mm RCA and want to swap for a 35mm one?
    I'm running a Hopper Stopper big brake kit with a ~280mm rotors and a PBR twin pots calipers.
  1. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  2. Bump Steer!
    Last Post: 19-07-2006, 07:16 PM
  3. 20V power steer bracket/pump
    Last Post: 08-01-2006, 06:28 PM
