Results 1 to 9 of 9
Thread: 1jz r154 in z20 question
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default 1jz r154 in z20 question
    as in title, ive got a *z20 1jz and r154, top mount gt35r, 3inch dump
    okay, my gearbox shit itself. suspected thrust washer and front bearing
    ive got a rebuild kit and custom made thrust washer, the problem is getting the gearbox out! my uncle is a mechanic and will be doing it for me, but the dump pipe pretty much covers the middle bolt on the right hand side of the bell housing ( will get pics if i can ) also the dump is hard against the firewall so it cant go back or side to side ( unless its a flange and not studs ). Apart from taking the turbo off the manifold which i dont want to do, i guess i could cut the dump off and get it re welded on i only got to drive it for 2 weeks!
    suggestions?
    87' z20 Soarer - 1jz Gt35r -
    EP Grease Monkey
    Default Re: 1jz r154 in z20 question
    not to sure, im having similar issues with mine, but as im replacing a turbo, ive decided to pull the whole lot out. much easier as the dump pipe is a pain to get to. In saying that i had some flex pipe put in there which made things a bit easier
    TAS
    sorry im a newb
    but how long would it roughly take to get the turbo and lines off the manifold roughly? everything is easy to get too. although id like to re do the down pipe in stainless or something while im there
    EP Grease Monkey
    not to sure, have you got a pic of your set up. mines pretty different to everyone elses on here with 2 sequential t28s so you should have a bit more room.
    To take a gt35 off wouldn't take very long. I would
    drain radiator
    take off water lines
    take off inlet pipe
    take off oil lines if accessable
    undo 4 bolts on turbo flange
    undo 4 bolts on dump pipe (or vband)
    then pull it out
    QUICKEST 1JZ'S IN OZ
    TAS
    heres the engine bay in question, ignore the piping layout its all guess work for the real stuff
    Nice except crazy piping Otherwise, my advice still stands
    TAS
    ha, the cooler pipe will be lower a fair bit, but thats the basic way its got to go and then through the "floor" instead of around the rail. id like to clock the turbo but thats another story
    EP Grease Monkey
    werd!! 1234
  1. Custom TAILSHAFT for MX83 + R154
    By Darrien in forum Tech and Conversions
    Last Post: 28-09-2007, 09:54 AM
  2. 1JZ & AFR gauge question.......
    By cptsideways in forum Tech and Conversions
    Last Post: 18-02-2007, 10:09 AM
  3. 1JZ JZZ30 ECU D1 & FC COR Pins question
    Last Post: 06-02-2007, 10:16 PM
  4. 1jz to 2jz
