Results 16 to 20 of 20
Thread: Fuel Pressure regulator, what do you guys recommend?
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: Fuel Pressure regulator, what do you guys recommend?
    If you don't need adjustable base pressure (ie to compensate for incorrectly matched injectors or lack of tunability), only plan on running less than 25psi (normal limit of pump fuel), don't really want to spend 5 or 6 times more than absolutely necessary and don't need the bling, then have you considered OEM FPRs (1:1 linear) from Toyota's more recent GTE engines?
    I've never had reliability or performance issues with factory 1JZ-GTE or 2JZ-GTE FPRs running over 300rwkw and up to 25psi of boost over 5 years.
    I've never had cause to remove any factory FPRs for the spare Sard Type RJ sitting on my shelf for years now, nor have I heard of any others having issues.
    If you do want to use an OEM one and get stuck finding one, PM me as I've a few spare JZ ones in the shed.
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    Terraopperative,
    What makes you think you need a new FPR ??? The factory Item you have is a stable, reliable, high quaity boost referenced fuel pressure regulator. It is perfect for the application and suits your engine regardless what power level you produce. Only in an off its head application where the physical flow volume of the reg becomes restrictive would it need to be changed and I don't see any 4AGZE ever getting to that.
    If your new head work and further development develops a power level that excedes the limit of your factory injectors then fit bigger injectors, don't do the dodgy and up the fuel pressure.
    If your after the bling factor and look of an aftermarket reg then by all means get one, and yes the Sard reg is the brand of choice.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    working hard Backyard Mechanic
    Should a 160kw ae86 4agte have one ?? ive only got stock supra injectors and its running factory regulator ??
    wanker Backyard Mechanic MS-75's Avatar
    As long as you have a manifold referenced regulator on the motor already (and being a 4agze I'd assume it does), there is no need to change to an aftermarket unit. The OEM unit will do fine, and RR regs can make tuning a PITA.
    As an example, on my 500+rwkw setup I had two fuel rails and two stock regulators. Size the injectors correctly and there is no reason to change. As mentioned before, the only time to change is when you exceed the flow capability of the stock reg, and that's a much bigger number than you are likely to make at a guess.
    Save your cash and put it toward injectors and fuel pump.
    HTH
    Sean!
    [email protected], WSID, COMPAK ATTAK, MAY 2006
    Jun 2006
    id also keep away from malpassi, had issues for years on a vl turbo, it fluctuated all over the place. replaced everything but it, as soon as a standard one was put on all issues were solved
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. Replies: 21
    Last Post: 30-12-2007, 12:26 PM
  3. a few pressure regulator and injector rail q's.
    Last Post: 20-11-2007, 06:34 PM
  4. Can an oil pressure sensor be used for fuel??
    By amichie in forum Tech and Conversions
    Last Post: 30-06-2006, 11:38 AM
