sure, but why would you want to?
if you are using stock injectors with higher pressure and an interceptor to tune it up high, then you may as well just run bigger injectors with an interceptor anyway..
think of rising rate regs as the ghey way to get more fuel
(and remember that your fuel pump volume decreases dramatically with higher pressures... or don't, but take a video when the PVC catches fires
anyway, both the fuel flow vs pressure of pumps and extra fuel from injectors with higher pressure is available on the net (as general idea and some specifics for supra pumps)
say you have 20psi boost. plus base 40psi. then you rising rate it to say 70 or 80psi...
are you going to buy a bosch high pressure pump to be able to get the fuel at such high pressure? i think notand if you did, then you wouldn't be using second ghey FPR anyway
