Page 1 of 8 123 ... LastLast
Results 1 to 15 of 111
Thread: JZA70 wont start...problem is very very wierd
    Default JZA70 wont start...problem is very very wierd
    Hey all,
    today my brothers (Spiller) JZA70 decided it didn't want to start, it cranks, fires once and then dies, ok so we whip out the old paper clip and bridge E1 and Te1 because the check engine light is on...it throws two codes the o2 sensor one (thats because it doesn't have it plugged in) and code 14...
    so after consulting the document which describes fault codes it was revealed that it might be a problem with either the ignitor or ECU
    So ive borred both items off a mate and tried them both and it still wont start, but as soon as we plug in my mates working ECU it doesnt even fire once...it just cranks...but the check engine light is off
    When we plug my brothers ECU back in the engine light goes back on...
    I have checked and rechecked the plugs on both the ignitor and ecu...but still having this problem
    Any help would be much appreciated!
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Default Re: JZA70 wont start...problem is very very wierd
    have you got fuel, check that you have fuel pressure at the rail, would be the best place to start, does it take a while to crank over, when you get it firing can you move the throttle and does this change it,
    yeah I think we might have to do fuel and spark tomorrow...
    fires almost first go...touching throttle makes no diff
    Also another possiblility is if you ignition barrel is on the way out, when it goes to start keep cranking it over on the stater motor and see if it wants to run, ive seem it a few times on different cars
    hmmm thats a possibility...but doubt it would throw a code 14 if that was the case
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Dec 2006
    hrmm ohk thats very weird Matt.
    It can be no fuel getting to the rail, check to see if the fuel pump works?
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    yeah he isnt taking the car back to whyalla with him...so ill fuck around with it this week
    Junior Member Carport Converter spiller's Avatar
    fucker of a car
    thanks for letting me borrow your ECU and igniter heng. +rep
    1990 JZMA70 Supra SOLD
    Dec 2006
    No worries mate, im always out there to help out and love it
    Matt if you need any help with it this week let me know.
    Junior Member Chief Engine Builder wiso's Avatar
    your crank and cam position sensors can also cause it to throw on code 14, i had an isues once i accidentlly damaged the wire to the crank sensor when i was working around the turbos, crank sensor wasn't registering, ignitor doesn't know when to fire, hence 14.
    worth a shot if you have fuel, have you looked at the coil packs? are they cracked really badly?
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    the coil packs have cracks in them but its been a while since ive inspected them. i have had issues with ignition break down under heavy load in the past but i think this is more due to the fowling of the copper plugs and pig rich factory tune.
    wouldnt it still fire if the coilpacks were fucked? as opposed to NO fire in ALL cylinders....???
    Western Aus
    pull the coil and test spark.
    shouldve been done first.
    ill get onto that tonight I think...see what happens...
    Quote Originally Posted by spiller
    If the cracks weren't bad it would still start and run a bit off. but if you had really bad cracks in all of the plugs, say a couple of mm gaps in all then i would hazard a guess and say they would all earth out and she probably wouldn't start at all
    89' MR2 AW11... His
    Xistant
    Guest
    do it now BITCH! now!!!
  1. Bigport 4AGZE Cold Start Issue and Flat Spot
    By sbyder in forum Tech and Conversions
    Last Post: 12-05-2008, 09:01 PM
  2. 7MGT-E Problem
    By 55Supra in forum Tech and Conversions
    Last Post: 19-04-2007, 02:31 PM
  3. JZZ30 Loom Vs JZA70 Loom
    Last Post: 12-04-2007, 05:33 PM
  4. Common Problem AE71/KE70 (Now with pics) Headlight/indicator Switch
    By stahlz_ae86 in forum Tech and Conversions
    Last Post: 18-07-2006, 06:13 PM
  5. Electrical Problem
    By AutoXCelica in forum Tech and Conversions
    Last Post: 15-01-2006, 03:32 PM
