Results 1 to 7 of 7
Thread: 20 Valve silvertop intake and exhuast Qs
    20v Silvetop / A40 3spd 1st year Apprentice
    Apr 2008
    Default 20 Valve silvertop intake and exhuast Qs
    Probably been asked before a million times but no searching really came up with the info I needed....
    WIll a RWD bigport intake manifold bolt onto my silvertop?
    What off the shelf options do I have for rwd extractors for my silvertop if any?
    cheers in advance...
    Aug 2006
    Default Re: 20 Valve silvertop intake and exhuast Qs
    No and not much
    Are you going to use the quads? Intake off a bigport won't fit a Silvertop at all, I have a RWD plenum for sale, its not the prettiest thing but it works.
    And as for extractors I THINK there are TRD copies, might pay to ask AJPS.
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    couldnt you use one of those quads to bigport adaptors and use it backwards?
    as for extractors, drill a hole and use 16v extractors
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
    Apr 2008
    Thanx 4 replies guys. I think i've just shown my ignorance of the differences between the 20v and 16v engines. I realise now that all i'm looking for is the plenum cut and shut 4 rwd application in a suzuki sierra. Due to the dizzy also being on the back of the head i'm pretty sure i have enough room to run the 90 deg intake pipe over the dizzy to the passenger side to fit an airbox. would there be any issues with running the intake from the rear of the engine in this case?
    it's not that hard to modify the plenum to move the inlet to the timing cover end of the motor
    th eonly difference between 16v and 20v extractors are two easly drilled bolt holes.
    As for the intake I am with JP, just butcher the stock one to face the front.
  1. Unequal camshaft duration 4AGE
    By toddw in forum Tech and Conversions
    Last Post: 01-02-2017, 07:04 AM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  3. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
