There's no link?Originally Posted by Wizzard
Non-VVTi JZs are not wasted spark - they have 6 outputs and would need 6 igf pulses - try that first.
If you're wasted sparking, are you sure you got the phasing correct?
What JZ ECU are you running? Your setup sounds like a mess.
The IGF that I have looked at are square waves, I'd expect the 2JZ to need a squarewave too. There is a time delay between the beginning of the trigger pulse and the igf pulse; if you set igf at the same time as igt it might not register as a valid igf signal. You shouldn't be concerned about the current - it's only voltage level based, not current. Have you looked at the waveform that your circuit provides?Originally Posted by Wizzard
Take a look at this, page 4:
http://lextreme.com/Adaptronic/1UZFE...ationNotes.PDF
I havent tried it but in theory it works for 1UZ.
Mos.
(THEY ARE NOT!!!)
