Results 1 to 7 of 7
Thread: 4AGE 20v ISCV
    Default 4AGE 20v ISCV
    Hey all,
    I'm chasing how the 4AGE 20v ISCV works. From what I gather, it's a 3 wire stepper motor but the details around the net are a bit sketchy. Is anyone able to provide any info?
    I've searched the forums, but 20v is hard to pinpoint because of the way the search drops short words.
    Nathan
    Default Re: 4AGE 20v ISCV
    they bolt to the head, and to a pull-push action to control air flow via PWM... not stepper motor.
    .... to make matters REALLY annoying, i'm lead to believe that they also restrict air flow as temperature rises with a bi-metallic valve (ie, are more open when at air temp), which is why they are bolted to the head.
    Of course a 20V workshop manual would explain all
    Interesting. Some of the descriptions on the net call it a stepper. Are the blacktop and silvertop ones the same?
    i thought all the 20v units were a PWM unit where the gze 16v ones are a stepper
    T'ville, QLD
    karl is correct i have one sitting on my desk as well as my manual on the screen
    2T out 4A in....
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    http://dutch.northwestmr2.com/Toyota...Control/12.pdf
    I found this a while ago, most of the abbreviations for Toyota engine control stuffs, the rest of the pages have good info too.
    idle up specifics
    http://dutch.northwestmr2.com/Toyota...Control/07.pdf
    Feb 2009
    Do you just leave the bottom pipe ,which usually goes to intake pipe, unblocked to suck in air if you are using trumpets/stacks??? if u block it off while its running it just dies....
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  2. 4AGE -> AE86 Conversion: Accessories question
    Last Post: 17-06-2008, 08:53 PM
  3. 3SGE BEAMS red top ISCV - engine idle RPM unstable
    By kanazai2001 in forum Tech and Conversions
    Last Post: 07-11-2007, 12:29 PM
