Results 1 to 13 of 13
Thread: Remote battery terminals
    Default Remote battery terminals
    I'm finally getting around to finishing my remote battery install that I started last year on my Hilux (RN85). Last year I move the battery to under the tray and connected it up, but because it is right in the center it is hard to reach. I always intended on installing remote terminals to make it easier to jumpstart or recharge but have only now gotten around to it. So here's what I have so far and what I intend to do.
    The battery has a single ground and a 4 +ve leads, 1 for the starter motor, 1 for the stereo and ancillaries, 1 for the fuse box and 1 for the A/C, EFI and fans.
    I have 1 stainless bolt for the +ve remote terminal (I couldn't get brass), and a kill switch.
    I want to have a +ve terminal post and a kill switch mounted in a plastic box with an easily removeable lid.
    I don't want to have to run new cables and not all the +ve cables will reach the spot that I want to mount the remote box (only the ansilaries and fuse box will reach.
    I'm going to run the -ve cable from the battery to kill switch before it terminates on the chassis. For the +ve, I'm going to cut the +ve post into the fuse box cable and move the ancilaries to the +ve post to reduce the number of cable coming off the battery. I'll draw up a circuit diagram tomorrow to make it easier to understand what I'm talking about.
    How does this sound, does anyone see a problem with it? I still have to find a suitable box too, so if anyone knows a company that can help me out with it, I'd really appreciate it.
    Dave
    Default Re: Remote battery terminals
    all about 12 volts at silverwater/auburn can probably help you out - had great dealings with them
    wa
    Im not sure what you are wanting to do but it sounds ok if it is what im thinking your doing
    Draw a diagram so we can see what you mean
    Junior Member Backyard Mechanic Sigmeister's Avatar
    Add more grounds. Either use a distro block and split them up around the engine bay and chassis or run multiple grounds directly from the -'ve of the battery. Sort of like an earth kit but don't spend some obscene amount.
    Classic JC Quotes
    "A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster."
    "Usually, a Range Rover would be beaten away from the lights by a diesel powered wheelbarrow. "
    "The Mitsubishi 3000GT is about as sporty as a game of Darts."
    Chiba
    Where can one buy remote battery posts in Brisbane?
    JP got some ceramic distribution posts for his AE71, they looked like they did the job really well, not sure where he got it from though, I forget.
    VPW sell them:
    LINKY
    Classic JC Quotes
    I think I woffled on a bit and confused everyone.
    This is my current power distribution.
    And this is what I want to do.
    Forum Sponsor Conversion King
    thought about using an "anderson connector"?
    or just a remote post setup off a BMW?
    the idea above looks good but i don't see a need for the remote post for the earth as there would be soooo many components that you could hook the earth to if you needed a jumpstart.
    linden
    Quote Originally Posted by Draven
    They actually moved to Victoria dude... like almost a year ago.
    High current anderson connectors are the shit. Buy from Jaycar.
    http://www.jaycar.com.au/productView.asp?ID=PT4424
    .... search for "anderson" on jaycar website.
    Stainless bolts should be fine for the remote terminal. Yeah, I don't know why I had the -ve post in there.
    Is the kill switch fine on the -ve side? What side does it normally go on?
    I'd still like a box to house the switch and ve terminal post. It would need to be at least 120x75x65mm; would prefer plastic and it would have to have a lid that can be quickly removed.
    Where would this Anderson connector go? If I'm interpreting your post correctly, it would replace the terminal posts, yes?
    My Missus is a Domestic Engineer BradW's Avatar
    Anderson plugs are the best. Mount it any where you want and yes, it would replace your terminal posts. You just need a set of jumper leads with an anderson plug on the end to plug into your car. We had these mounted on places around my old work ute for jump starting from. Made life much easier.
    Also, main switch will be fine on the earth but I would put the terminal post or anderson plug (whichever you choose) on the battey side of the switch. That way you can charge your battery and still have the switch off and there is also no chance of mistakenly jump starting the car with the switch off, which could cause damage to your alternator, ecu, etc when you disconnect your jumper leads. Hope that bit makes sense.
    Brad
    Old Corollas never die...
    My KE30
    Ok I've removed the -ve post as I can just coonect sraight to the chassis where the -ve is connected.
  1. Alternator/Charging issues.
    By DoctorDubb in forum Tech and Conversions
    Last Post: 07-03-2008, 05:44 PM
  2. Installating a battery backed siren + piezo alarm - pics.
    By Howieau in forum Tech and Conversions
    Last Post: 27-12-2007, 11:28 PM
  3. Stock/Standard JZS147 Aristo Battery CCA Rating?
    By Esteban in forum Tech and Conversions
    Last Post: 09-10-2007, 07:40 AM
  4. St18x : Rearmounting the battery
    By Classique71 in forum Tech and Conversions
    Last Post: 07-02-2007, 12:03 AM
