Results 1 to 15 of 21
Thread: undoing bolts
    Default undoing bolts
    i have a bolt on both sides of my wishbones that i need to undo to get my new springs in i have got all the rest out but these ones just wont budge. im thinking of geting a air rachet today if anyone has any advice please post
    car: 1976 rt104 corona
    chears
    Aaron
    Default Re: undoing bolts
    What are they holding? The first thing that comes to mind is heat. You can spray it with WD40, put some eucalyptus oil on it, or use a priduct called yield (if you can get it). Give it a dose and wait.
    P.S an air ratchet wont help much - a rattle gun will help.
    GT4 Freak, and Conversion King Squid's Avatar
    Extend your ratchet arm with a big breaker bar?
    either that or dynamite
    Use a piece of pipe to extend the ratchet arm - works for me most of the time. Rattle guns sometimes help, sometimes not ... it's easier to really screw up the head of the bolt/not with a rattle gun.
    If there's one thing I know, it's never to mess with mother nature, mother in-laws and mother freaking Ukrainians
    Administrator Domestic Engineer mynameisrodney's Avatar
    applying the force to the nut instead of the bolt will also help
    Penrith BC
    as mentiioned:
    rattle gun
    ruttle gun + metrinch
    rattle run + metrinch + oxy torch
    oxy cutter
    ../delete/ban
    tech moderator
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    angle grinders are the cause and cure of most automotive problems
    try everything before you try cutting.
    breaker bar, rattle gun (best bet), massive breaker bar. try using 'single' hex spanners instead of the mulit hex ones too-help to stop stripping.
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Just wait till it rusts out
    Have you tried hitting it with a hammer? The shock sometimes loosens stuck bolts.
    Act
    BIg breaker bars work wonders,
    Long poles/pipe on said breakers bars is better.
    Also Ed's Met wrenches worked wonders on my semi stripped bolt in the g/box
    thanks heaps ill try a breaker bar if that dont work then looks like ill be cuting it off
    whell if it ends up stripping, get some stilsens on to it. most of the time they are quite big so u can really do the job then.
    P.S. Its hard to go wrong with a rattle gun and single hex socket. unless u snap the head of the bolt.
    wuss, they are easy to get out
    just get a breaker bar and hang off it
    The boobs are back
    Junior Member Backyard Mechanic rob1's Avatar
    Tas
    "or snap the head of the bolt"
    Which will solve the problem anyway...............
    welll get the rattle gun and do it then!
    cant use a rattle gun wont get in there so its all up to the breaker bar now
    hears a pic
  1. Negative Rear Camber bolts for MA61/MZ10/MX73 !!
    By bbaacchhyy in forum Tech and Conversions
    Last Post: 03-08-2014, 09:12 PM
  2. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  3. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  4. Flywheel Bolts 1JZ-GTE R154
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-12-2005, 06:05 PM
