Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: 1JZ ignition module grounding
    Professional Amateur Grease Monkey sil80 1J's Avatar
    Feb 2008
    Default 1JZ ignition module grounding
    does anyone know if the ignition module (igniter) grounds itself through the casing to the body or whether there is an earth wire somewhere in the system?
    Sil80 1JZ chasing 400rwkw
    Update: 4/5 the way there on 21 PSI, 350.3rwkw
    http://i112.photobucket.com/albums/n...L801copy-1.jpg
    Default Re: 1JZ ignition module grounding
    Earthed via Ground wire in the 4 Pin plug.
    Feb 2008
    couldnt ask for a better response!!! thanks mate!!!!
    Feb 2008
    what does IG- and IGF on the 4 pin plug mean?
    IG- is the signal that goes to the dash (and the diag box on the side of the engine), it is the tacho signal from the igniter to the dash.
    IGF is the ignition verification signal wire that goes from the igniter to the ECU. This wire / signal is used to tell the ECU if the ignition event was completed successfully as far as the igniter could tell......
    Hope that helps...
    Feb 2008
    awesome!!! thanks for the info mate, thats perfect!
    hey heres a related article from supramania, where a guy puts it extra grounding coz his was corroded. might be interesting.
    http://www.supramania.com/forums/showthread.php?t=52217
    Feb 2008
    cool cool, should do this as a point of interest even if mine is ok. thanks for the link mate
    Feb 2008
    also... is the power on the 4 pin plug straight from an ignition source or is it relayed? if so what is the trigger for it?
    Quote Originally Posted by sil80 1J
    Pretty sure it is +B power, which is via the master relay, which is triggered from the ECU M-REL output...
    Hope this helps...
    Feb 2008
    cool cool, thanks mate, its all coming together slowly... i think ill just run it off the same relay i use to power up the coils.
    thanks again for your help mate, most appreciated!!
    Yep that should work fine!
    It's not. +B is the output of the EFI relay, which supplies the ECU, fuel pump and things lile VSVs, ISCV, etc but not the injectors or ignition system - those usually come through the AM2/IG2 circuit, mostly directly through the ignition switch, sometimes through an IG2 relay.
    While the EFI relay is often controlled by the ECU, the injector/ignition power supply is separate and controlled by the ignition switch only. Part of this is so that if something fries the ECU so it's constantly supplying the M-REL signal, you can still shut the engine down by turning off the ignition switch.
    Yep, as wilbo said that will be fine, as long as it's triggered off the ignition switch and not the output of the EFI relay.
    Mos.
    Quote Originally Posted by Mos
    Interesting, so thats the reasoning for it.... Never knew that.
    Mos.
    Hmm I thought it was +B for the igniter, but maybe I'm wrong Ah that's right (Looking at the diagrams) the igniter is always labled with +B, but it is actually switched via the ignition...! I can understand how I forgot it was switched ignition and not really +B
    Anyway sorry for the bum steer, and thanks to Mos for correcting me
    Also as mos says the injectors def aren't on +B so that gives you the safety (regardless of the igniter I feel )...
    Last Post: 12-07-2019, 06:11 PM
  2. 1JZ vs 7M alternator useful info and pics
    By Ribfeast in forum Tech and Conversions
    Last Post: 22-06-2009, 05:10 PM
  3. 1JZ performance head build. Advice/help?
    By ReQuieM in forum Tech and Conversions
    Last Post: 09-07-2007, 09:08 PM
  4. Replies: 5
    Last Post: 21-12-2006, 10:46 AM
  5. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
