Results 1 to 15 of 19
Thread: Attn 1G-GTE owners
    Junior Member Grease Monkey Les's Avatar
    NSw
    Default Attn 1G-GTE owners
    (1) Does anyone have a part number for the 1g-gte (3rd gen) spark plug ? need to do a service and forgot where i put the old spark plug boxes !
    EDIT
    Old forums good...
    http://forums.toymods.org.au/index.p...t=0#msg_738921
    * NGK - BCPR6EP-N-8
    * Same plugs as 7mgteu, or if money is tight try 7mgeu
    * Denso K20PRU11 ... gapped to 0.8mm
    * NGK platinum plugs. You can try one of these:
    BCPR6EP-N-8
    BCPR6EY-11
    BCPR6ES-11
    (2) Who has upgraded starter motor for 1G-GTE ? Did you go aftermarket or stuck with original .. Know of any good places in Sydney to purchase a new one and possible fit it as well - want to get it done right first time.
    Thanx
    2003 Clio Sport 172 N/A
    1985 RA65 Celica T/T
    1983 AE86 Levin Sprinter S/C
    1997 Lancer RICE
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Default Re: Attn 1G-GTE owners
    http://members.optushome.com.au/mkha...nfo/index.html
    Some random useful info on that page In regards to the starter I feel that a toyota item should be fine as long as it fits and works ok!
    I've used the std 1g-gte starter, and that's worked a treat. I can't imagine why you'd need to upgrade it unless maybe you have a higher compression ratio or something?
    Secondly, I do actually have the 1g-gte std plugs in mine. I can't remember what they are, but I can find out for you if you want, I can go get them out of my car.
    Facebook | LinkedIn
    NSw
    1) Well, it's not an upgrade as such ... it's more an issue of "need to replace" We think the solenoid has goooooooooone hence it starts when cold, but once warmed up, it will play up and start maybe 1 out of 5 times. We can hear a clicking sound but it will not crank. First, we will disconnect and hook it up again - possibly loose wiring, but more likely to be old starter playing up ? Any thoughts ?
    2) No need to trouble yourself re plugs dude, I have managed to find a few links to the plugs: From various sources for gen 3 1G-GTE for future reference (thanks Nark, Hydra, JCMF):
    * NGK - BCPR6EP-N-8
    BCPR6EP-N-8
    BCPR6EY-11
    BCPR6ES-11
    1997 Lancer RICE
    Les,
    The problem with the starter on the 1GGTE is a very common toyota one. The trigger wire for the soleniod is a tiny gauged wire from the ECU. What needs to be done is have this hooked up to trigger a new relay and give it a big blast of current from a better source.
    Dylo
    NSw
    Quote Originally Posted by Dylo
    Les,
    Dylo
    Hey, thanks. Is this from experience Dylo ?
    1997 Lancer RICE
    Well yes I know its a common problem as a mate with a 1G had this problem, and mine has always done it. (I just havent been stuffed to fix it yet) Mine only has drama's when its cold rather than hot like yours! Cranks one out of every three shots, so its no biggy.
    Here is exactly what im talking about!
    http://www.toymods.net/forums/showth...4990#post54990
    1) I'd go with the loose wiring option. Particularly given that resistance increases as a function of heat..
    2) let me know if you want any info on my plugs.
    Facebook | LinkedIn
    NSw
    OMG hard-on ... THANKS ..
    Stradlater, plugs shd be cool for now, will just get some NGK's - thanks !
    1997 Lancer RICE
    Just make sure you gap them to 0.8mm
    It could also be dirty contact points for the starter motor
    In regards to choosing spark plugs (more general info!) make sure you choose the right sizes as well. I was looking at plugs the other day and noticed that there was "B" and "BC". B's are much larger and wont fit down the tiny holes in the 1G. I think there are other spark plug codes that will fit but I can't remember them.
    And
    Another note on the plugs..
    with the NGK plugs, if they are rated "R" they have a much higher resistance than the non R plugs.. This resistance is put there to 'protect' factory ecu's.. If you have an aftermarket one, or just don't feel like adding unnecessary resistance to your HV ignition system, don't get the R plugs.
    Facebook | LinkedIn
    NSw
    Starter Problem (Mine)
    NOW it seems it does not matter if it is hot or not, the car WILL sometimes start and sometimes it wont while hot - or warmed up.
    1) car is running, i.e. warm. Stop car and start immediately - no problems
    2) as above, wait 10 minutes, while washing car, crank, click click click. no start. Wiggle the key a few times quickly, and it starts ..
    It is definitely a contact problem ...
    1997 Lancer RICE
    Yeh, crawl under there and check it out Might be a really easy solution!
  1. Attention Classic Celica/Toyota Owners!
    By -NiCkeL- in forum Victorian Events
    Last Post: 31-01-2006, 10:43 AM
