Results 16 to 19 of 19
Thread: Attn 1G-GTE owners
    TAS
    Default Re: Attn 1G-GTE owners
    FWIW, the starter on my 1GGTE (2nd gen) when I got it was intermittant. My auto electrician said that this it was a common problem for these starters - apparently the wires inside crack (whether he meant this particular starter, or toyota ones of this type, or all toyotas ones, I don't know. I had it completely rebuilt.. new internal wires, brushes, oversize contacts etc for around 100 bucks (which was a fantastic price).
    Junior Member Backyard Mechanic ndgcpr's Avatar
    i thought the clicking was a sign of the solinoid trying to throw, thus no noise when turning the key i would think is a trigger wire problem but a clicking i would think is the main lead problem, i think mine has cracked it clicks sometimes and if you go and wiggle the main think wire it seems to help it start
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    Junior Member Grease Monkey Les's Avatar
    NSw
    Quote Originally Posted by ndgcpr
    What did you do to fix this ? If you have that is ...
    2003 Clio Sport 172 N/A
    1985 RA65 Celica T/T
    1983 AE86 Levin Sprinter S/C
    1997 Lancer RICE
    well at the end is a sort of eye terminal that i thought had broken off between the screw bit and the wire comming in, it was still covered in rubber insulation so if i sat the two lumps of metal together it made a half decent contact and was held there but the insulation, i was having problems when i was away and planned to fix it when i got back home, but after fiddling with the main lead at the starter motor it seemed to work and hasn't faulted again, i believe that it is still broken and the large amount of current flowing through it has created a type of weld that seems to hold it together, rightfully i should go and buy a new lead from the local car accessories place (like autobarn of super cheap) but really have just been lazy and not bothered, i will get under it one day and check it all out properly.
    I must add that none of this is proven, this is just what i believe has happened and it makes sense to me.
  1. Attention Classic Celica/Toyota Owners!
    By -NiCkeL- in forum Victorian Events
    Last Post: 31-01-2006, 10:43 AM
