Results 1 to 5 of 5
Thread: 1JZ-GTE gaskets
    Your mum loves my Grease Monkey TasCressida's Avatar
    Apr 2008
    tasmania
    Default 1JZ-GTE gaskets
    hey guys.
    in need of a exhaust manifold gasket. im in tassie so there being hard to come across lol.
    any idea who i can source one from?
    can someone mainland based hook me up with one. after reasonnable quality,
    Default Re: 1JZ-GTE gaskets
    if you can re use the origionals is the best option as aftermarket ones are shit in comparision,
    Tasmania
    Look in Parts wanted for a thread created by me. Roadrunner and Hengsta both said they had some so if you PM them they should be able to help you out.
    The images below might also help you out, they dont have the full part number but gets you started and if you show the Toyota parts dealer, then it makes it a little easier.
    I did get it quoted as i was looking at a 1JZ that had an exhaust leak but couldnt find the last part numbers (i presume where for the actual exhaust - for which it looks like he was looking up a JZZ30 and i dont have those). Here is what i got (my description in brackets):
    TO-1717988400 GASKETINTAKE NONARL QTY:1 (upper > lower intake gasket - not required)
    TO-1717788400 GASKET INLET JZZ30 QTY:1 (lower intake > head - not required)
    TO-1717388410 GASKET, EXHAUST QTY:2 (head > exhaust manifold)
    TO-1727888400 GASKET, TURBO JZZ30 QTY:2 (exhaust manifold > turbine)
    You would also need: 17279 QTY:2 (turbine > dump merge)
    Apr 2008
    tasmania
    wow thanks again guys! wil take them in to toyota and see what comes of it.
    thanks rich will pm them ...should have mentioned i need them for a single turbo manifold.
    WOOP WOOP lol getting closer now!
  1. EPC Help - 1JZ gaskets
    By EldarO in forum Tech and Conversions
    Last Post: 12-03-2008, 06:36 PM
  2. 1JZ Exhaust Manifold Gaskets
    By Pure_In_Sanity in forum Tech and Conversions
    Last Post: 26-08-2007, 09:38 PM
  3. 1jz exhaust gaskets
    By ripfast in forum Tech and Conversions
    Last Post: 02-07-2007, 01:36 AM
  4. where to get cheap 1jz head gaskets
    By 1jzracing in forum Tech and Conversions
    Last Post: 05-07-2006, 01:50 PM
