Results 1 to 12 of 12
Thread: 1jz exhaust gaskets
    Junior Member Grease Monkey ripfast's Avatar
    Default 1jz exhaust gaskets
    Hi all
    Sorry if this has been covered before but couldnt find anything in the search
    Putting dump pipes on my 1jz, should i replace the exhaust gaskets between the turbos and the exhaust they are pretty flat? if so can anyone tell me where i can get them from or what the part number is, approximate cost?
    1985 VK Commodore with 1JZ-GTE
    1989 GZ20 GT-T Soarer with 1G-GTE
    2008 IS250 with not enough power
    Default Re: 1jz exhaust gaskets
    I reuse mine and there fine, even when there flat metal garrett ones etc, you can buy them aftermarket from exhaust shops etc can get them in, or through toyota but there expensive, a t3 gasket kit (dump & Manifold) cost a mate 70 dollars, obviously not toyota but it gives you an idea.
    i just have the standard exhaust gaskets, i just thought that becuase they are a bit more squashed than usual id need new ones, but i suppose takin dumps out to chnage them isnt that hard anyway
    they "should" be changed, as they're crushable metal gaskets. that said, I know of plenty of people who re-use them and have no issues
    I just bought a new set from CH toyota for peace of mind
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    i re-used mine when i put my dumps on.
    havent had any leaks so far
    so does anyone have a part number so i can check with toyota in Adelaide?
    you could always e-mail CH toyota and ask
    http://www.chtoyota.com.au/
    they're a really good toyota for import parts
    2JEJ Grease Monkey petespipes's Avatar
    i have always reused the old ones with no problems,it is often useful to do something to stop the bolts from loosening though ie locking tabs
    flanges bolting to ct12a turbos on the 1js came loose on me once,i used locking tabs fabbed from thin mild steel plate
    [email protected]
    its ok not to know everything
    cheers fellas
    they are your pipes pete, i finally got them to fit after all we tried last year, it wasnt pretty but an oxy and a hammer helped in the end
    reuse them mate, they go forever.
    JZA70|R / 12.45 @ 111 mph.
    yeah i checked them closer today, but cause i tried so hard to get them in the first time i dont think ill use em again cause one of them has crumpled so its not completely flat anymore, i dont think it will seal.
    grab another from someone thats gone single. or a wrecker or something no need to fork out for new ones.
  1. 1JZ vs 7M alternator useful info and pics
    By Ribfeast in forum Tech and Conversions
    Last Post: 22-06-2009, 04:10 PM
  2. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 04:04 PM
  3. Hunting a particular SW20 exhaust
    By Lonewolf in forum Tech and Conversions
    Last Post: 04-05-2006, 01:33 AM
