Battery charged ???
The 100kw 4AGE engine in my Suzuki Sierra does the other week, just came to a complete stop. I towed it home and checked all the usual things, fuses, connections, relays etc but found nothing out of the ordinary. Mechanically it seems fine so I am thinking it must be something electrical. The symptoms I have are that the fuel pump does not work when cranking and there is no spark. I have swapped the distributor and tried another ECU. Other than this I dont know what could be wrong with it. I just know its going to be something stupid and easy to fix but I really dont know if there is anything else that might be obvious. Open to all suggestions.
Battery charged ???
did you try testing the ignitor? or the coils?
start with checking power to the ignition switch with a multimeter.
then check power from ign swithc to ECU
then check power to injectors
then check power to fuel pump etc...
find where the voltage trail stops, and use multimeter
EFI main fuse
EFI main fuse as above.
I would look into why no fuel pump, as all faults will probably be related and it will be easiest to find.
Find the relay, and make sure it has a +ve feed with the key on, and earth and a start feed.
Thats' all it need as when you power it with the start feed and earth the earth,
it connects the batt/ign feed to the pump.
I'd guess you have no power on the batt/ign feed so will be a fuse or fusible link problem.
- KE70 Corolla Dx -
- 500hp+ 7AGTE 20V turbo -
- MRS/Hayabusa turbo **sold**
Hey,
What you may find is that the ignition switch is dropping ignition when you go to crank, have had a couple of those kind of problems at work. Just a suggestion as you said the fuel pump only stops working when you go to crank.
Hope it helps.....
Thanks Guys, all replies noted. I havent looked back at it yet but to be a little more specific, I have no fuel pump or spark at all, not just on crank. I hooked the pump straight to the battery to have it pumping but as there was no spark still no ignition. I have power to the ECU but there doesnt seem to be anything coming from it eg no power to the pump relay. This is why I tried another ECU. Thinking it might be the CAS I tried another dizzy but still the same. I will just have to keep chasing the power as oldcorollas suggested but thanks for the input.
