Results 1 to 12 of 12
Thread: Where is the JZX90 ABS/TRC ECU Located?
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    Default Where is the JZX90 ABS/TRC ECU Located?
    As per the title. I pulled apart the glovebox, its not in there. I couldn't find it in the boot walls, and It wasn't in under where the stereo goes... soo... WHERE IS IT?
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    Default Re: Where is the JZX90 ABS/TRC ECU Located?
    Part of the main ecu maybe?
    nope definitely not. its a standalone ECU. seen them on yahoo auctions..
    i would assume behind the glovebox insert where the ecu is. Soarer ones are all located there i assume jzx90s would be the same ;-)
    RA23 - Twincharged
    JZZ20 - Daily
    definitely not behind the glovebox.
    ok i finally found the ABS Diagnostic jumpers (hidden away under the drivers kick panel) and bridged TC and E1 and now have a Code 43. Anyone know what that might indicate? (I'm assuming its a code 43 coz the TRC light flashed 4 times, pause then 3)
    EDIT - BINGO! Got It! Thank you PlanetSoarer
    TRC - 43 - Malfunction in the ABS or TRAC (Brake) Control System
    Footnote - If a malfunction is detected, the TRAC OFF Light will stay on
    Exactly my problem. OK If i only knew where the damn ECU is I'd check it now!
    I would have thought the ABS light would have flashed if there was an ABS problem ?
    the TRC and ABS systems are aligned as they share the same ECU. If theres a problem in the ABS system external from the ECU then the ABS light will flash, but if its a ECU problem or TRC problem then the TRC light will flash.
    this is the ABS/TRC ECU
    Question.
    What size front and rear tyres do you have?
    same as stock. 225/55/R16. see where you're going with that though.. fair call
    That looks like the ecu that is a bit further under the driver's feet than the diags connector that you just found (well, on an x100 anyway...) You'd need a torch to read it, tho.
    NQLD
    in the MX83 the ABS computer is between the back seat and the back of the boot
    might be the same as JZX90
    Quote Originally Posted by The Last Streetfighter
    i think you're spot on. i'll pull it apart and have a look tomorrow. got a new ECU today...
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 07:10 AM
  2. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 12:42 PM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
