Results 1 to 6 of 6
Thread: 1G Taking off the head?
    Junior Member Grease Monkey Ray_GZ20's Avatar
    Default 1G Taking off the head?
    Hey, just wondering if possible to take off 1g head without taking turbo's and inlet man off? And if so is it wise to do this way? Thanks
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Default Re: 1G Taking off the head?
    Possible? Of course it is. But you'd have a much easier time if you do remove the inlet/exhaust manifolds. The combination of manifolds, turbos, and the rest will make the thing weigh a fair bit i'd say.
    last time i took my hesd off i done it that way, was easy enough, i did have a single turbo ther though not the standard twins.
    cheers steve,
    1ggte, 11.22 @122mph
    Car Alarm Guru and Grease Monkey GTtwin's Avatar
    I wouldn't be too keen on trying it. You still have to remove turbo oil and water lines anyway, and thats the shittiest bit of the whole job anyway.
    The worst part of removing the water lines is when the crappy weak studs that hold the water pipes to the turbos break
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    I reckon the easiest way of taking the head off is by pulling the whole motor out. Unless the cars on the hoist, getting to some of the bolts will be a pain in the arse. Sure there are a bunch of electrical plugs plus the trans but taking the head off while the engine is out is much easier.
    Good luck.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. 2s to 3sge head swap?
    By sam-131 in forum Tech and Conversions
    Last Post: 24-03-2007, 06:42 PM
  3. 4AC broken head - remedy?
    By slapper in forum Tech and Conversions
    Last Post: 25-01-2006, 05:59 PM
  4. Head flow thread, please post for all to see
    By Mr DOHC in forum Tech and Conversions
    Last Post: 19-01-2006, 05:41 PM
  5. Oil pipe on gen3 3sgte head
    Last Post: 31-10-2005, 01:08 PM
