Hey
That is really a question of how well you can mig weld. Well providing that the radiator can be welded with a mig. ie. is it just steel. If it's an alloy of some sort you wont' be able to mig it.
Other than that, just keep the heat down on the mig, and if your not very experienced i would't really recommend using a radiator to learn on. If you have your own mig, try gettin some scrap steel about the same thickness and practice for a few hours on it. Biggest tip that sooooo many people seem to overlook: CLEAN UP YOUR STEEL BEFORE WELDING.. i.e. does rust/paint conduct electricity???? NO!!! what is the main principle behind welding???? Electricity.
so just knock the paint off a bit with a grinder, not too much, you don't want to take too much steel out.
But anyhow, i don't know what you're like at welding, i could just be patronising you. Sorry if that's the case. However there are so many people that say "mig welding is easy, you just pull the trigger".... yet their welds look like birdcrap and couldn't hold as well as chewing gum.
But that's enough welding lesson..
Good luck with it
(but probably won't as they all suck...)
