Results 1 to 5 of 5
Thread: Moore front camber on RT142
    Mar 2008
    Default Moore front camber on RT142
    I've heard the best way is to just install sigma lower control arms.
    Is it just as simple as that?
    And if i do this about how much camber will i have?
    Cheers guys. =]
    Default Re: Moore front camber on RT142
    I've seen it done on a TE71, the result was stupid amounts of camber (at least 4 degrees) and wheel clearance issues.
    If it was me I'd install camber tops and if they don't offer enough adjustment get the struts bent.
    RT142 arm == 310mm
    Sigma arm == 340mm
    All the data is there, figure it out yourself.
    Forum Sponsor Conversion King
    sigma = roughly 3degrees more than you have now.
    dont forget tie rods and rackends will probly need changing
    If you are planning a brake upgrade, xt130 struts will give you roughly 3 deg neg camber as they have a different strut angle to rt142 struts. Thats even with using standard camber tops and lower control arms.
  1. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  2. camber adjustment for st162
    Last Post: 29-04-2006, 07:38 AM
  3. xa6x - xt14x front end convo ??
    By sam-131 in forum Tech and Conversions
    Last Post: 08-01-2006, 08:32 PM
  4. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
